Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
Unread 13-04-2005, 01:34
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Master Code 11?
Hello everyone,
Today someone forwarded me an email with some updates about what parts would be available at nationals and what kind of support we could expect. Well, I lost the email, but I'm pretty sure I heard something about a Master Code version 11 for the OI. I am wondering whether or not it was a typo. I think I remember also the email saying that it was not required... which makes me rethink writing it off as a typo. I checked the IFI site and there is no version 11 Master Code available for download. Did someone else read the email more thoroughly than me and/or not delete it and know what I am talking about?
Thanks,
Steve
Unread 13-04-2005, 01:51
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Re: Master Code 11?
IFI is currently working on Master Code 11,
it fixes an issue with PWMs 6-12 where the pwms would become active for a fraction of a second, when the robot is not powered in disabled mode (the way it is normally powered at FIRST events) it will not be required for The Championships, it isn't a typo,
Hope that helps, and here is the link for update 19
http://www2.usfirst.org/2005comp/Upd..._Update_19.pdf
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 13-04-2005, 02:11
Re: Master Code 11?
Thanks Big Mike, I searched the forums and the FIRST site, but couldn't figure out where the information in this email came from. The person who sent this to me is sleeping like any sane person should be right now
-Steve
Unread 13-04-2005, 14:54
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Master Code 11?
I plan on taking the "If it ain't broke, don't fix it" approach on this.. I have yet to see this problem at all, and even if it happened to us, the only pwm effected won't hurt anything at all.
Unless its a requirement, I won't be using it.. I don't want to have to diagnose a problem between it and our code at nationals.
Unread 22-04-2005, 16:10
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Master Code 11?
I think it's a requirement to use v10, since last year's versions (6 and 7) won't work with the new OI. If you're using the 2004 RC, you'll need to upgrade. If you're using the 2005 RC, you're ok.
Unread 22-04-2005, 19:48
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Master Code 11?
Jamie,
V10 is all that is required regardless of which controller you are using.
In V10 we discovered that the PWM outputs on both the 2004 and 2005 RC would "jump" when communications is established with the OI unless the DISABLE pin is shorted on the competition port.
This "jump" manifests itself more when you use PWM 7 though PWM 12 as your outputs.
V11 eliminates the "jump" and that is all... As long as you can guarantee that no team member will be injured because they powered up on a tether (you are using low numbered PWMs or have a dongle plugged in at all times), V11 is not required.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
heres the code. y this not working omega Programming 16 31-03-2004 15:18
