Go to Post rookie teams are like kids - making them is easy but raising them to maturity can kill you - Wayne C. [more]
Unread 20-04-2005, 10:33
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
limit switches
Hi,
We've been having a little trouble using limit switches. We get the value registered when the limit switch is pressed, but when it is released, the value doesn't change back. I figured the first thing to check would be the wiring. I haven't seen much on chiefdelphi after searching on limit switches, so if you could provide a wiring diagram, that would be helpful. Then secondly, maybe sample code for referencing the limit switch. ThankS!
-Stephen P.
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
material cost limit haverfordfords Fundraising 3 06-12-2004 19:21
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Need help with custom switches archiver 2001 3 24-06-2002 00:35
