Go to Post Driving and using the cell phone and taking a picture with it. Where is your Safety Captain? - GaryVoshol [more]
Unread 23-04-2005, 11:55
Dominator_Legen's Avatar
Dominator_Legen Dominator_Legen is offline
Dominator_Legand
AKA: John Fawzy
no team (DL X-Soldire)
Team Role: Leadership
Dominator_Legen is an unknown quantity at this point
Question Measure Rover Speed
Hy,
i'm using a 4 DC Motor to move my rover, and i need to measure the speed of my rover , i.e. the distance that the rover move, i heard about a fotoreflector sensor, dose this sensor do the jop, and if there are another sensor, what is it?
and how can i interface it to my pc, i have an interface card, from velliman (K8000), which allow me read an analog value from 0v to 5v,?
Please advice me..
Thanks in adavnced for whatever help.
Dominator Legend
[ Dreaming To Builde A Robot ]
Unread 23-04-2005, 13:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Measure Rover Speed
A photocell type sensor is one way to do it. You could also use infrared leds and receivers, or you could use quadrature shaft encoders. I'm not sure how you would hook up any to your PC.
Unread 25-04-2005, 08:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
John,
Most teams use some form of sensor that counts wheel rotation or fractions of a rotation. These can take the form of an optical sensor that closes a contact each time it sees a change (from light to dark or dark to light) and a segmented field, mounted on the wheel. Two such sensors, on a wheel with eight black and eight white segments (16 transitions in 360 degrees) can give you accuracy down to 1/4 of an inch (under a cm) and direction information. Teams were given gear sensors in their kits this year that also did a nice job as well but you need to have metal gears and a place to mount them. In either case, they are not an analog output. They produce digital pulses which can be read by any digital input.
Al
WB9UVJ
www.wildstang.org
________________________
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
Remote Control Rover Help Dominator_Legen Math and Science 7 12-02-2005 03:35
**FIRST EMAIL**/LEGO MARS ROVER SPECIAL OFFER Damian Manda FIRST E-Mail Blast Archive 6 27-04-2004 18:47
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Tape measure proboscus tito General Forum 24 29-04-2002 15:56
