Go to Post I wouldn't want to force another me on everyone! - Andy Grady [more]
Unread 26-04-2005, 21:21
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Analog and digital input question
I know that the FRC controller must be present on the robot and control radio communications etc., but is there anything in the rules that says that sensors need to be connected to the FRC controller? or can they be connected to another board?
For example, if I wanted to use a gyro and accelerometer, would I need to connect them to the FRC controller and then relay data to the other board?, or can I hook them up to the other board directly?
In addition, I would assume that the camera would be considered pretty much the same as any other sensor, but just to make sure, would it be legal to directly interface the camera with another board?
In all cases the FRC controller would be handling all radio communications and controlling all pwm/relay outputs.
Thanks,
--Robby
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Some EDURobotics Problems squide Robotics Education and Curriculum 9 20-01-2004 10:27
