#16
Re: Using IFI Controller witout Operator System
You can read the RC reference guide for the 2003 controller here. |
#17
Please review my post on the first page. You do not have to run this in autonomous mode. It will run fine by your code in normal mode.
The difference in autonomous mode is a bit is set on called autonomous_mode. If this is 1 then your code takes over control of the robot. If the bit is not on then you allow the controlls to operate the robot. But you can allow you code to run the robot all the time by itself without anyone operating it. |
#18
Thanks everybody for the replies! I've been waiting on this information. I definitely have a pre 2003 controller (either 2001 or 2002 since 2003 and 2000 are still in use) I like the older controllers because I'm not familiar with C at all and I'm pretty fluent with PBASIC since I used BOE-Bots while testing stuff. I would just use the BOE with this, but it simply doesn't have enough ports. I guess I'll have to finally move up to C this summer. But the 2003 controller has autonomous? Wow, I never knew that... I just reprogrammed our 2003 robot after having to get it working earlier this year but I never saw anything about the autonomous. Oh well... So If I use the 2005 or 2006 controller, will I have to initially start the RC with the OI before becoming completely autonomous, or will it automatically start up without an OI?
#20
You will need the OI only once, connected to the RC by tether cable, in order to set the team number to zero. After that, the RC will always run autonomously until you change the team number back to something non-zero using the same method.
#21
Cool, thanks!
| Building an arena controller | CJO | Control System | 32 | 29-03-2005 07:04 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How much code can an IFI controller handle? | Larry Barello | Programming | 7 | 10-02-2002 19:06 |
