Go to Post But then again, no one's robot ever is fully working to how they want it before the first tournamant. - #1Transgirl1140 [more]
Unread 08-05-2005, 14:36
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
BASIC stamps
Can anyone tell me which pins on the bottom of this BASIC stamp i connect a pwm wire into in order to connect it to the servo controller underneath it
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 09-05-2005, 09:04
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: BASIC stamps
Phil,
To be safe you should check the parallax web site.....
Essentially all of the pins marked P# are available as inputs or outputs and so are eligible to be used for PWM outputs. I am not sure which servo controller you are using but typically they require a serial out line to the the controller. Again, any of the pins marked P# are available. You then use SEROUT to send the command to the servo controller. Check the documentation that came with your servo controller.
Check this thread for more info.
Andy Brockway
Team 716, The Who'sCTEKS
Remote Program Execution in Visual Basic Jeff Waegelin Programming 6 14-06-2004 21:15
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
BASIC Stamp Error mpatterson Programming 4 22-01-2002 12:08
