Go to Post Actually, FIRST Is hoping the reverse, that your bot will be "Ball damage proof" - Rombus [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 14-05-2005, 18:05
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Re: Website Balance...
I never thought about it, but I use pixels for fonts. I'll have to update myself on this stuff again. I know that and heard several people say that div tags are better and I made the last two versions of our team's website with div tags, but both times, they caused so many problems that I ended up disecting the coding and switching to tables. The tables work perfectly, even though they load slower, it works better. I think that div tags have to be developed more before I will start using them.
The worst is when I put an image in a div tag that is larger then the division. I set the div width to a certain width and the image to 100%. The image, in some browsers, tries to be 100% of the entire page, but is moved to the right, or where ever the div is, and a left/right scroll bar is used. When I use tables, images always work correctly. I can use percents with images in tables and for the tables so the page resizes for different resolutions. If anyone has tips for me on this, PM me or email me or something.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 14-05-2005, 18:09
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
That's why I really wish companies like Microsoft would actually make their browsers W3C standards compliant. This way when your making a major site, you don't have to work extra for their lack of sensibility.
http://www.mikesorrenti.com/
Unread 14-05-2005, 18:49
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
IE7.0 will be 100% CSS 1 & 2 compliment and maybe 3 complient.
Its not in that link, but its what I've heard from a couple reliable places.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 10-05-2005, 13:43
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Originally Posted by DarkJedi613
I check my forms with PHP. The user can't get around me now. hah!
Any thing which actually matters is done through PHP, but the Javascript is just there as a convience to users so that they get quick feedback.
Just out of curiosity...why do you guys choose XHTML over HTML? I know it's supposed to be neater and a lot of codes don't work, etc. But what are the actual benefits? Or do you just like saying you use XHTML ?
I use it because it's the standard and helps to ensure greater compatibility. And yes, saying XHTML is more fun.
Something else I forgot to ask about...what resolution do you design for? I design for 1024 x 768 (and it'll always look good in 1280 x 1024 too since thats my default). But i tend to not give much thought to 800 x 600. A fault I know, I'm trying to solve this by using CSS layouts now instead of tables, etc. But, anyway, what do you do?
I design for "any" resolution through CSS, but generally it has to look good on 800x600 for me to be happy. As with my use of XHTML over normal HTML, I aim for as high a level of compatibility as possible. I'm pround to say that every website I design can bear the W3C CSS and HTML (usually XHTML, but sometimes...) logos...
And as a side note, I find the HTML Tidy Firefox extension an invaluable tool for creating perfect code.
New Website being created ! mtaman02 IT / Communications 25 26-01-2005 03:37
Web Excellence Award Winners (Which Teams?) OZ_341 Website Design/Showcase 39 10-07-2004 20:19
Website Excellence? Tom Bottiglieri Website Design/Showcase 4 15-03-2004 02:43
Looking for an easy website for your team? Jack Website Design/Showcase 2 30-12-2003 23:32
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
