Ok this has been bugging people on our team for a couple years and I haven't been able to find anybody else who knows how to do it propely. Anybody know how to do chain properly so that when the gears move the chain moves as well. Just looking for idea's, I figure if we all network idea's together we could all accomplish this quicker.
Re: Chain..... How you do it properly?
I don't know how to make it perfectly as you described but we could make a research group to find it out heuhehue.
I just knew about the "chainer" a few posts ago... |
Try Dr. Joe's Chain Path Visualizer
http://www.chiefdelphi.com/forums/sh...threadid=32174 |
im not shure weather your talking about gear reduction or active chain tensioners could you please clairfiy what your doing and what you need help with
I tried to make chain that would move right using some already made chain (came in 2 parts that had to be contrained together repeatidly). While I could get the chain to stay together on it's own, it would break once I tried to constrain it to a gear. Because of the way gears are made (not just in and out, I think it is called involute) there is no "center" in the gaps to place the chain, only possible centers (there's about 3 "center" points to constrain to). My chain was either slack, broke (how does Inventor do that?), or Inventor was yelling at me for breaking it. Therefore, the most obvious route doesn't work.
I'm not talking about chainer, I'm talking about how to constrain it straight to the gear.
I'm not to familiar with Inventor, so take this with a grain of salt.
I work with SolidWorks for 3D CAD mainly. I would assume that you can mate the chain somehow to the center of the gear to cetralize it in the grooves so it has no sideways off the gear movement, and then mate some part of the chain to the center of the arcs in the gear's Internal Diameter.. I'm not sure if the CAD software would be smart enough to release the mate to the chain and the gear's arc as you rotated the chain through it's path. I know the version of Solidworks (2001) a few classmates and myself tried to use to make a geneva wheel we couldn't get the mechanism to work correctly, but we did have some sucess. In essence, you need a temporary mate to a link and gear when it is in contact, and for that mate to release itself when the chain leaves the gear. constraints = mates btw. SolidWorks calls 3D constrainst between assemblies Mates, and constraints between lines in sketches constraints. Sorry if there is any confusion due to my wording. edit: another cool geneva wheel animation: http://www.brockeng.com/mechanism/Geneva.htm More cool mechanisms: http://www.brockeng.com/mechanism/index.htm Last edited by Elgin Clock : 14-05-2005 at 15:32. |
#10
This movie shows as far as I got with this problem. The links are actually constrained tangent to a hidden chain path (like J's famous "chainer"). It would lock up with more links and also when the three links got to the end of the straight path and tried to transition to the curve on the left end.
The links are actually "pulled" by a hidden block which is constrained to the path and is moved by the animator dial. Without the chain links holding it up, it would follow the whole path around. This was done in Inventor 6 a couple of years ago, btw. |
#11
I'm having some problems to dimension my "chainer", my last link always has to be smaller or larger to fit the chain exactly.
Is there any pack of formulas to do it? *I'm using different sized sprockets thanks in advance |
#12
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| chain ridding up and off sprocket problem... | davidhoare | Technical Discussion | 4 | 04-02-2004 10:13 |
| 25 or 35 chain? | Alan Ing | Technical Discussion | 24 | 02-03-2003 13:56 |
| 1/4" chain and links from small parts | archiver | 2001 | 2 | 24-06-2002 00:18 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
