Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. ;) - Billfred [more]
Unread 05-11-2005, 07:44 AM
atmaturen atmaturen is offline
atmaturen is an unknown quantity at this point
Send a message via AIM to atmaturen
Mini RC step-down
Is it possible to run the mini-rc controller off the standard 12v battery with a step-down converter, and if so does anybody know of one which would work? Also, can we use a spike on the mini?
Unread 05-11-2005, 08:27 AM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: Mini RC step-down
Mini-rc = VEX ? Mini-rc = Isaac? Please explain and we will try to give you an answer that makes sense.
Joe J
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 05-11-2005, 11:48 PM
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
We use the LM350T voltage regulator to operate an EDU-RC on 12 volt power. The digikey part is LM350TNS-ND that includes short circuit and thermal protection. The output voltage of this regulator is set with two resistors, one fixed at 120 ohms and one adjustable in neighborhood of 570 ohms if you want 7.2 volts out. We use a 1K adjustable resistor, as I recall. Refer to the data sheet that you can get from digikey by looking up the part.
The regulator is capable of handling up to 3 amps, but you have to deal with the power dissapation requirements of your current load (4.8 volts times whatever the load current is) by mounting the regulator on a suitable heat sink. Don't forget to insulate the mounting and use heat sink grease on both sides of the mylar insulator.
If you have a different mini-controller that requires a different voltage, adjust the 1K pot until you get the right voltage.
Legacy documentation for the EDU-RC indicates compatibility with the spike relays. The current documentation does not, but it would be hard to imagine that IFI had made them incompatible. If you are using a different mini, as queried by Joe, your mileage may vary.
Eugene
Senior Project 05: Mini competition to help fundraise for local rookie teams Alex Cormier Fundraising 0 10-07-2004 03:58 PM
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 04-12-2004 11:15 AM
mini cooper robot? Brandon Martus Chit-Chat 10 04-02-2004 07:27 PM
