Go to Post Water game. - dlavery [more]
Unread 11-05-2005, 23:17
Timmyd's Avatar
Timmyd Timmyd is offline
HAHA...i like pi
AKA: Tim
FRC #0022 (Double Deuce)
Team Role: Mechanical
Timmyd is just really niceTimmyd is just really niceTimmyd is just really niceTimmyd is just really nice
Send a message via AIM to Timmyd
pic: H.O.M.E.R.
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
Unread 11-05-2005, 23:31
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: pic: H.O.M.E.R.
nice job
I don't remember ever seeing you use that end effector, what is the purpose of the two angled pieces at the top?
also I like the way you have the three tubes welded in a triangle on the probe section of the effector i'm assuming that this is help prevent left to right swinging of the tetra, am I correct?
Unread 11-05-2005, 23:46
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
Team Role: Coach
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Re: pic: H.O.M.E.R.
I also <3 the end effector and part of me (the very tiny egotistical part, mind you) would like to think that 22 drew some inspiration from us when we came down for the Southern California Regional. We were able to grab and stack 2 consistently when everything was mechanically sound in our robot, albeit with a much more inconsistent system, which ultimately proved to be our downfall. 22 originally had a gripper just like 254's and they proved to be adept with that as well, but I remember them being concerned with the idea of stacking two tetras with a new design. I also remember watching one of their matches in Atlanta as soon as I could get home after practice on the Friday afternoon and seeing them seemingly stack 2 and going . The beauty of this was that they didn't have to change the robot significantly at all!
Said it before and I'll say it again, we cant wait for 22 to come back up here next year, almost as much as we wish we were down there now, or at least at championships.
Woburn Robotics, Class of 2005.
Unread 12-05-2005, 00:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: pic: H.O.M.E.R.
Originally Posted by Scott Morgan
nice job
To keep tetras from getting stuck on the arm.
254's original "grabber" had problems with that, and they solved it with a kite shaped frame around the prong that stuck out, so that the tetras were supported and had a very hard time getting stuck.
Looks like 22 modded that design and came up with the one shown here.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-05-2005, 17:39
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
Re: pic: H.O.M.E.R.
Cory is right. We had problems with tetras getting stuck or if we raised the arm high it would slide down the arm. Thats why we have the two angled tubes on the top. They are welded at the same angle as the tetra, 120 deg. We also made everything longer so that we could hold onto two tetras at the same time. The two tubes to make the triangle was actually thought up and done in Atl. It was to, you are correct, reduce swinging. It worked well enough.
Student: Team 22
Mentor: Team 4
Unread 17-05-2005, 20:23
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
Re: pic: H.O.M.E.R.
Oh and by the way the three tubes used to be one and i had the idea of having the two lower tubes welded on even though other people did not believe that it would make a difference.
P.S. Thanks AL (who is from 254) for the good welding job on the tubes even though you thought it was a stupid idea.
Unread 17-05-2005, 21:28
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: pic: H.O.M.E.R.
Team 22 was absolutely amazing. They were our pit neighbors also, so we saw a lot of their robot. I was absolutely shocked when I hears you and stang were knocked out. You guys easily coudlve gone all the way.. GOOD LUCK NEXT YEAR
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: Tigertrons 222 05 Pic #2 team222badbrad Robot Showcase 4 01-03-2005 08:25
pic: Local Paper shot pic at Robot "Bon Voyage" send off falconmaster Extra Discussion 1 26-02-2005 10:34
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
