Go to Post You can learn just as much from building a small robot as you can from a large bot because all of the key concepts are the same. - Greg Needel [more]
Unread 17-05-2005, 09:35
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
BASIC programming
Does any one know of any tutorials or anything that can help me learn the BASIC programming language to program an older rc and OI? if so please pm me or post here i would greatly appreciate it! or if anyone can help me like 1 on 1 over like aim or whatever messenger you use i would greatly appreciate your help!!!
Unread 17-05-2005, 10:06
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Re: BASIC programming
Hey -
There's some information in this thread. Hope it's of use to you.
I know some basic BASIC, but don't know of how much aid I'll be. You can try asking me, though
Good luck!
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 17-05-2005, 11:33
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Here's the Programming Reference Guide for the old controllers.
Here's the official Basic Stamp Reference Manual which documents all of the BASIC commands.
In fact, most of what you need to get started is on the IFI Legacy Documentation page, in the 2001-2003 section.
Good luck, and feel free to message me if you need help.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 17-05-2005, 12:15
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
I concur.
To be honest, most of the PBASIC language is non-standard BASIC. Knowing BASIC is more of a hindrance than a help sometimes.
Read the PBASIC manual and you'll be off to a good start.
Some advice.
Forget/ignore the PBASIC manual that has anything to do with direct management of the I/O pins. They are pretty much useless because the RC more or less limited the pins of the STAMP2 to those talking to the Master CPU, The Programming Port (actually not a bad way to get a peripheral to talk to the STAMP2 program via RS-232) and some pins that more or less just turned on LEDs.
Get used to the PBASIC line processing method and avoid using too many parentheses. After coding for a while, I would end up with so many layers of nested ('s and )'s that the code was untouchable. Things got better from me once I decided to go with the Zen of PBASIC rather than fighting it.
Know the ins and outs of 16 bit unsigned math. It is a beast that will bite you in unseemly places at exactly the wrong moment. I can't tell you how many strange robot quirks were tracked down to some 16 bit overflow that only happens when the phase of the moon is just right and the tide is high and the robot driver's middle name has a T in it ;-)
Good luck.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Organizing a programming team. scitobor 617 Programming 7 28-01-2005 19:18
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
Help programming in Visual Basic xxlshortys Programming 0 06-04-2003 08:54
