Go to Post And then have FIRST throw a copy of the Atkins diet book in with each kit... - dlavery [more]
Unread 19-05-2005, 22:32
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Information on gears inside the FP Gear Box?
Our team is working on an offseason project and we will like to use the gears of the FP gear box. We need to know what the PD is in all the gears, the preassure angle would help but is not necessary. I think if we get the pitch of the gears we can figure out what the PD is. I did a lot of research with some of meam mates but perhaps we just couldn't find it, if thats the case please direct us to it.
Thanks in advance for all the help.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 19-05-2005, 22:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Information on gears inside the FP Gear Box?
Well, first off let me say that they are all plastic. You can bet your bottom dollar that the first one in the lineup is a 32DP 20 degree PA.
(I'm not sure why you are referencing pitch and diametral pitch separately because usually when we say pitch we do refer to diametral pitch - number of teeth per inch of diameter, perhaps you mean to be asking for the pitch diameter? But yes, you can calculate that if you know how many teeth and the DP)
As for the rest, I'm really not sure.
Unread 19-05-2005, 23:09
AKA: Dave
Originally Posted by sanddrag
Im not sure why you are referencing pitch and diametral pitch separately because usually when we say pitch we do refer to diametral pitch - number of teeth per inch of diameter, perhaps you mean to be asking for the pitch diameter? But yes, you can calculate that if you know how many teeth and the DP)
Yes that is what I mean the pitch diameter.
Gear Pressure Angle and Pitch. Patrick Wang Technical Discussion 20 13-08-2002 20:33
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
