Go to Post FIRST games are complex and rely on design and intellectual capability much more than the average sport. - Chris is me [more]
Unread 22-05-2005, 21:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Looking for smaller 1/2 ID ball bearing
I'm looking for a 1/2" ID ball bearing that is either smaller in diameter or width or preferably both than the standard width of .25 and standard diameter of 1.125. If the width is .25, it needs to have a flange (and flange need not be included in the .25 of width). If the width is less (preferable), it doesn't need the flange.
I don't want to use a bushing and I have already checked all the usual places.
I know such a thing must exist, I'm just hoping someone can find it because I couldn't.
Either:
-a diameter of .875 and a width of .25 and a flange
-or a larger diameter and width of .188 and no flange
would be ideal.
And I'm not looking to go for something at more than $10 apiece but if you find something that is more, I'll still take a look at it.
EDIT: I found these http://www2.towerhobbies.com/cgi-bin...?&I=LXD097&P=7 which are the right price but I think they are a little too small.
Unread 22-05-2005, 22:40
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Re: Looking for smaller 1/2 ID ball bearing
http://www.qbcbearings.com
They have some miniature ball bearings (in the catalogues)
http://www.bocabearings.com/main1.as...25&w1=.500&t=I
That's a large list of inch bearings they carry. The 1/2" bores are near the bottom with ODs from .750 and up.
I found these by doing a quick google search for "miniature ball bearings." Most companies do not have prices in their catalogue, such as those two pages, but if you call the company you can usually get a quote for the items. Sometimes they can even help you find a bearing if you have specific requirements. Hope this helps some.
By the way, what is your intended use for these bearings? During the season I used some 5/16 by 1/2" miniature ball bearings and they became one heck of a problem because my parts put too much stress on the bearings. Usually as the bearings become smaller and thinner the tolerances become smaller and will need to be in more controlled environments.
_Alex
Unread 22-05-2005, 23:06
Team Role: Teacher
Thanks for the links but neither of those places have exactly what I need. I really don't want it to be just an open bearing. I'd like it to be sealed or double shielded. Also, I'm thinking .75 OD is too small.
Unread 23-05-2005, 02:06
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Few links...
http://www.wmberg.com/catalog/pdf/b00j033a.pdf
Check the bottom row.
http://www.wmberg.com/catalog/pdf/b00j035a.pdf
Yeah it's small and unshielded.
http://www.dynaroll.com/catalog/thinsection.htm
Small, but sheilded. But you might have a time actually buying it.
And finally, a really crazy idea.
http://www.spyraflo.com/products/nee...ons/index.html
Second paragraph there. Yes, it meets very few of your specs. But I don't know the actual design and felt it likely that this might actually work for ya.
As a note to all, all of this came from a little searching on http://www.globalspec.com which really handles this sort of thing rather well.
Unread 26-05-2005, 16:51
ghansel ghansel is offline
my amp goes to eleven
AKA: George H.
FRC #0019 (Big Red Robotics)
ghansel is infamous around these parts
Top result on google.
http://bearingsdirect.com/products/i...=category&id=1
Unread 26-05-2005, 18:30
Team Role: Teacher
Originally Posted by ghansel
Not even close. There are no .5" ID bearings in the Miniature category link you posted, and the .5" id bearings in the "radial bearings" category are even wider than ones from other sources.
I have convinced myself the exact thing I want does not exist, so, I reworked my design to use a 1/4" wide bearing that is left sticking out of the hole by 1/16" No problem.
Unread 26-05-2005, 19:44
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
PIC Design has got something like the ones you listed in the edit above; part number is E5-2.
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
