Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 24-05-2005, 16:39
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
New Module system
Due to the fact that the current module system is so easily broken, it is going to undergo a massive restructuring. (The first evidence of this is the openfirst.info.php files found in CVS.)
The basic idea is that a module could be installed, uninstalled, or updated without worry about conflictions. This would include DB tables, translations, hooks, or anything else.
There would be several core "modules", which are used by the central code and likely universally. They would include:
  • The Module Manager (installing, uninstalling, and configuring modules)
  • Documentation (the "help files")
  • Users (sessions, option storage, login, permissions)
  • Edit (universal markup parser)
  • Language (translations)
  • Hooks (low-level extensions)
Each of these provides a functionality that is used by several (if not all) modules. They would be implemented mostly as a seperate module, but are used by the core.
The directory structure of modules could be as follows:
  • /<module> - The basic files.
  • /skins/<module> - CSS and images needed by the module
  • /documentation/<module> - documentation for that module.
  • /language/<module> - Translations of the text used in that module.
None of these are required. However, a mature module should have all that are applicable.
Any ideas? Comments?
Unread 25-05-2005, 17:30
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: New Module system
I'd like to see something incorporated so that upgrading/installation/uninstallation can be done in a standard way by just calling something within each module. That way the update Module Manager can be a relatively simple thing but those who write modules can have complex update/install/uninstall functions performed.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Boilermaker Regional Wireless Scouting System. Josh Hambright Regional Competitions 4 21-03-2005 19:48
**FIRST EMAIL**/A note on the FRC scoring system sanddrag FIRST E-Mail Blast Archive 13 17-03-2005 04:37
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
