Go to Post That goal is going to commit suicide by the end of the regional........so many balls @_@... - DanDon [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 29-05-2005, 15:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
CSS frames
Ok... so from looking at the CSS playground (which I discovered thanks to this thread), I've created a CSS frame based layout for a site I'm working on. It looks great on Firefox, and works in IE, but there's a small (well, two, but the one annoys me more than the other. ) problem. Here are two screenshots: (+the Firefox pic, so you know what it should look like.)
Firefox, the one that works:
IE, not scrolled: (see, it looks fine!)
IE, scrolled: (not the arrow and circle...)
I can't figure out why the select ends up on top. I've tried forcing the z-index below the header layer, but it doesn't help. Any ideas?
The CSS Playground JohnBoucher IT / Communications 6 29-05-2005 16:41
CSS Based Design Brandon Martus Website Design/Showcase 13 07-05-2004 19:46
Arggg stupid css design..... Adam Y. Website Design/Showcase 16 22-04-2004 19:37
Reasons for not using frames Raven_Writer Website Design/Showcase 49 17-05-2003 20:24
# of frames Adam D 3D Animation and Competition 8 16-03-2002 22:45
