Go to Post 1/4" baltic birch plywood is most of our metal. - z_beeblebrox [more]
Unread 19-10-2005, 15:00
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: Adding Bluetooth to Vex
The easiest way to do it would be to use the "programming" port on the vex as opposed to the radio port.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 20-10-2005, 08:06
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Does the programming port on the VEX use RS-232 voltage levels (<-5V = 1, >5V = 0) or TTL voltage levels (<1.4V = 1, >1.4V=0)?
Sorry for the silly question. I am out of the loop on VEX stuff.
If the Programming Port uses RS-232 voltages, then you could use an off the shelf Blue Tooth radio like this one.
Otherwise, I would use the TTL voltage level serial port and use one of the modules that is compatible with that voltage level.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 20-10-2005, 10:56
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
programming port is ttl. programming dongle, however, has level shifter in it and since you need one anyway to program the controller to listen to the serial port, there's no point in not using it with an rs-232 level radio if that's what you've got. otherwise a ttl level radio could be used on either the programming port or the rx and tx connectors up top.
Unread 20-10-2005, 11:25
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
This Radio, by AirCables, is an RS-232 radio that have used a lot and that I love. It has only 10M range, but it is beautiful in terms of its performance. I have not done it myself, but the engineer at AirCables tells me that if you crack the case it has the ttl signals easily available on pins. Highly recommended.
Joe J.
Mentor
Team #88, TJ2
Unread 07-12-2005, 11:53
AJBelayer AJBelayer is offline
AJBelayer is an unknown quantity at this point
Ok I am new to the vex world but I have been in programing (C, C++, java, assembler, etc.) for a while now and I want to add bluetooth to my vex robot for control, I assume this is done easiest over the serial port connection and i have rad this entire thread. Has anyone successful done this? If so would you be willing to help me get figured out where to start and what radios work best? I would like to stay with the 100m range bluetooth.
AJBelayer
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
Useful VEX Tools Joe Johnson FIRST Tech Challenge 4 26-04-2005 18:48
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
