Go to Post Now really, who would want to try and go against Andy Baker? That's like trying to single-handedly outscore 25, 254, and your choice of triplet with a shopping cart. - Billfred [more]
Unread 20-04-2002, 16:31
JamesJones JamesJones is offline
#0180 (SPAM)
JamesJones is an unknown quantity at this point
lexan bender
Is anyone bringing to Nat's a hot wire bender capable of bending 1/4 lexan and can accomodate a sheet 28 in wide?
If not, got any advice on making one cheaply?
James
Engineer/Coach
Team 180 SPAM
Unread 21-04-2002, 13:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
We bend it cold...
We have had good success just bending polycarb sheet on a normal break.
We typically only use 1/8 inch thickness max. but I think we have bent 1/4 inch as well.
Anybody else have better data than my foggy memory?
Joe J.
Unread 21-04-2002, 14:50
asher asher is offline
None #0031
Rookie Year: 2000
asher will become famous soon enough
We've gotten creative with a few soldering irons, not the prettiest thing sometimes but it works.
ashley
Unread 21-04-2002, 15:12
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Curved Bends.......
One of our engineers created this lexan bender out of some sort of heating rod thing....
all u do is set this device on top of the lexan where u want to make a nice bend with a radius...then after it heats for awhile [no melting ] then u just quickly take the lexan and bend it over something else with a radius (table edge, pipe, etc.)
Works pretty well....we used it this year to bend our side panels rather than using the traditional break...
Now for your question....i dont remember if we put that in our trailer....but if we did it will be able to bend 28 in, but u will not get a bend with a 90 degree angle....
Purdue Alumni
Cummins, Inc.
Unread 21-04-2002, 15:36
Unsung FIRST Hero Woodie Flowers Award
David Kelso David Kelso is offline
#0131 (C.H.A.O.S.)
Team Role: Leadership
Rookie Year: 1994
David Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud ofDavid Kelso has much to be proud of
Send a message via AIM to David Kelso
We use a sheet metal bender too. If 1/4 inch is too thick, do two sheets of 1/8 and glue together with methylene dichloride.
Unread 21-04-2002, 16:18
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
we just used a blow torch. our mentor/teacher went to his room at the school, grabed a blow torch, came back and melted/burned the lexan, and then bent it into the shape we needed. it actually worked out pretty well too.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 22-04-2002, 22:53
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
A good 'ole heat gun (paint stripper, whatever you want to call it) does great when it comes to bending lexan or PVC. Our team uses it all the time. Just make sure as to not over heat it and it works great.
~Tom Fairchild~, who also found out late one robotic evening just how effective the heat gun is at reheating pizza - two thumbs up!
Former member of Team 122
Unread 23-04-2002, 12:29
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
I think we might bring ours, it's an electrical current running through a piece of what looks like ribbon but it has some metallic properties. We have a cool lexan barn roof shaped cover on our bot which we did with that. Come see us and maybe borrow our contraption if we brought it.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 08-05-2002, 23:03
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
This is a little late for Nationals, but we also user a heat gun and a jig made out of two pieces of metal to bend the polycarb. We would have used our metal bender, but it was a few inches too short.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 12-05-2002, 18:50
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
ALITTLE LATE BUT...
i know this is a little late for nationals but...
If in the futur you are going to use this method keep in mind that we scored it first. We were bending 1/4" lexan so i set the skill saw's blade to a 1/8"depth and went a long a straight line that we wanted to bend at. This was critical to a clean angle.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Can LEXAN exceed robot dimensions? RAWdealer59 Rules/Strategy 13 05-03-2003 22:05
What is allowable contact with the lexan rail on the ramp? Randy Ai Rules/Strategy 1 06-01-2003 17:17
How many comp's did u attend? / The condition of last year's bot? purplehaze357 General Forum 30 09-08-2002 11:34
Lexan, the wonder material archiver 2001 12 24-06-2002 02:10
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
