pic: steering
Re: pic: steering
Its looking good!
Is that the motor in the backgorund? |
Re: pic: steering
what in the world is it
Re: pic: steering
Re: pic: steering
I hope you are planning on using something more reliable than string but it is looking good so far.
Re: pic: steering
Re: pic: steering
100 lbs is not alot considering you are generating force to move a person. you also might want to consider a rigid member in there something like a rod on a hinge so it maintains the distance between the members better then just knots in string |
Re: pic: steering
arp |
Re: pic: steering
How thick is your plywood? (I'm assuming that's what the 'fins' are made of) Because it doesn't look all that thick and doesn't wood bend fairly easily when it has such a large surface area (based on the comparison to the person next to it) If the wood started flexing during your 'flight' is it possible that it would horrible mess up your steering abilities? Have you considered a more rigid material by chance..
#10
Re: pic: steering
Are you going to have a kill switch? Just in case you break the string or loose control? Its looking great i might take on a project like this towards the end of summer
#11
Re: pic: steering
arp |
| pic: 2005 Team 1549 Rookie Pic | Eupher | Robot Showcase | 7 | 01-03-2005 11:20 |
| pic: WBI-461 Rowdy Pete 6 Pic #2 | Josh Hambright | Robot Showcase | 10 | 27-02-2005 02:10 |
| pic: Team 107 Bot Pic 01 | brent_107 | Robot Showcase | 13 | 26-02-2005 14:49 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
