Go to Post hiring a monkey may not be a good idea i used that method once and it cost me a fried motherboard... - Cuog [more]
Unread 07-06-2005, 11:28
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
Gyro Calibration
AQRS-00075 is the gyro i am trying to calibrate via Kevin's code. I can get the gyro to 1800 when it is at 180 degrees but for some reason it never ever goes back to 0 when i return it to its original position. I am moving it pretty slowly so i do not think it ever gets saturated. I was wondering if people ran into similar problems and whether it was a hardware problem (the gyro is broken) or technicial issue (the gyro we have just doesn't cut it)
Thanks for any input
Unread 07-06-2005, 13:29
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Gyro Calibration
What scaling factor did you end up with after calibration? How much drift are you seeing (degrees per minute)? How far from zero is it when you rotate it back? Did you follow *all* of the instructions contained in readme.txt and gyro.h?
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Calibration roboticsjenkins Programming 11 21-02-2005 20:39
arm-limitting gyro PD loop producing some strange results ZZII 527 Programming 8 16-02-2005 02:30
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
