Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 08-06-2005, 21:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Chemistry Question
In Chemistry, what does capital Q stand for and how does it relate to spontaneity and concentrations and chemical equilibrium (and conditions)? Thanks.
Unread 08-06-2005, 21:50
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: Chemistry Question
Q is used to test how close a system is to equilibrium. Set up your K-expression and plug in the concentrations. If Q=K, you are at equilibrium. If Q>K, then your product concentrations are too high, so the reaction will move in reverse to equilibrium. If Q<K, the reaction will move forward to equilibrium.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 08-06-2005, 22:01
Greg Marra's Avatar Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
no team (The Blue Alliance)
Team Role: RoboCoach
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Yup, Q is just the temporary relation to K. I always like it because the way we learned to use it, to test hypothetical reaction concentrations, it was totally made up and didn't relate to anything real.
Unread 08-06-2005, 22:25
AKA: DFB
FRC #0125 (NUTRONS)
Oops, forgot to relate it to spontaneity. If Q determines the reaction should go forward, Gibbs free energy for the forward reaction is negative and therefore is spontaneous. If Q determines the reaction should go in reverse, Gibbs free energy for the forward reaction is positive and the forward reaction is nonspontanious. If Q=K, Gibbs free energy is zero and the system is at equilibrium
Does this help?
Unread 08-06-2005, 22:32
Team Role: Teacher
How do you find Q though? Does it relate to pressure or temperature or anything? Basically, what makes it different from K?
Unread 08-06-2005, 22:36
AKA: DFB
FRC #0125 (NUTRONS)
You can use pressure or concentration. It is different from K because it can be found at any point, given pressure or concentration. The expression for Q is the same, but the pressures or concentrations given do not have to be at equilibrium. Q determines how the system will get to equilibrium.
Unread 09-06-2005, 00:09
AKA: DFB
FRC #0125 (NUTRONS)
Alright, I guess I'll make an example.
In the system of acetic acid (HC2H3O2<----> H+ + C2H3O2-), Ka=1.8x10-5. If [HC2H3O2] = [H+] = [C2H3O2-] = 1.0 M
a. Find Q
b. Predict which direction the reaction will shift in order to reach equilibrium
a. First, write the Ka expression, which will be
[H+][C2H3O2-]
[HC2H3O2]
The expression will be the same as the Ka expression. So Q also equals
[H+][C2H3O2-]
[HC2H3O2]
Plug in the values for concentrations given. This gives you (1x1)/1.
Q=1
b. Since Q>Ka, the amount of products is too high (you can think of this as having to make Q smaller until it reaches Ka). Therefore, the reaction needs to shift to the reverse reaction until Q=Ka
The same thing can be done with Kc and Kp in gaseous systems.
Does this help?
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
A question about control system options computhief263 Control System 7 04-02-2004 14:46
