Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 17-06-2005, 08:37
Entropia Entropia is offline
Entropia is an unknown quantity at this point
Question Problem controlling a servo
Hey
I took the easy way of controlling a servo motor (currently using Hitec HS-311) with PC via its parallel port. I hooked the servo to 4.5V power source and the signal lead to parallel port's data pin 8. I wrote a Win32 application to control it, but it seems to have no control. When I turn the control on, the servo moves to the beginning of its motion range and stays there. I have tried to alternate the "refresh" rate (from 5 milliseconds to a hundred milliseconds) but this only changes the frequency of the servo when it heads to the beginning of its range. I have also tried to alternate the position pulse width from 500 microseconds (0.5 milliseconds) to 2500 microsends (2.5 milliseconds) but it has no effect. Any ideas what might be wrong?
The program is available for download here: servocontrol.zip 220kb
It is hardcoded to use 0x378 parallel port and to use datapin 8 (pin 9 in the connector).
I would be hugely grateful if someone could hook an oscilloscope to the parallel port and see if it outputs proper control pulse/signal. I'm going to take my servo to a local shop and have it checked incase it's faulty.
Regards, Entropia
Unread 18-06-2005, 14:54
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Problem controlling a servo
The pulse going to the servo should be between 1mS (far one side) and 2 mS (Far other side). When you get outside of that, you get un-predictable results.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 18-06-2005, 18:36
Problem found; faulty parallel port. It gives out a nice 5V when not loaded but even a single LED attached to it drops the voltage down to 2V. And that's not enough to even signal the servo. Next up: building a buffer circuit. Recommendations appreciated.
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
