Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
Unread 22-06-2005, 21:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
PTO on robots
Has anyone used PTO (power take-off) on a FRC robot other than 60/254 in 2004? If so, pics? Thanks.
EDIT: In case you don't know what I mean, it is using the drivetrain motors/gearbox/etc to power other mechanisms. Has anyone done this?
Unread 23-06-2005, 17:17
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
FRC #0862 (Lightning Robotics)
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
Re: PTO on robots
Good question.
I know we talked about it in 2004 - use a power take off from the drive wheels to power a winch - but we got behind on everything else - by talking about things like power takeoffs - which ment we had less time to do stuff like a power takeoff - which ment we .... nevermind...
If you did it, how did you "turn" the power on and off? What kind of clutch, basically? Home made? Purchased? Complex? Simple?
Brian Graham
Unread 23-06-2005, 18:36
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: PTO on robots
254/60 did it through mesh shifting -- they had an additional piece which would bolt onto their transmissions and through pneumatics, they can shift a gear in/out of power.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 23-06-2005, 18:40
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: PTO on robots
Team 824's 2004 robot used such a mechanism to power its winch. It was, in essence, a lovejoy coupling that was engaged and disengaged from the driveshaft to alternately power the drivetrain or winch.
The team suggested its implementation early on as a way of minimizing weight in two torque-heavy applications, but the leader decided it was too complex. Late in the build period, when it became evident that weight was indeed an issue for the team, he ordered the make-shift clutch to be built and, as a result, it turned out pretty shoddy. Given more time, I could have done a much better job.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 23-06-2005, 19:42
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: PTO on robots
On the line of using one mechanism for multiple things, here are a few:
In 2004 Wildstang 111 used their pneumatic lifting drive train to not only get up the six inch steps, but to hang as well. Lots of teams used stuff like this, like 258 and others.
Also, one proposed design during my year with MVRT 115 was to use the motor that drove the hinge on our 2X ball grabbing arm, and through a shift mechanism to engage a winch, to lift the robot onto the hanging bar. I machined it but it was never used.
It seems that most of these PTO situations were during 2004, using a system to hang. Anybody got any other examples of using a mechanism (not necessarily drive train) to do multiple things?
Unread 23-06-2005, 21:36
24 Hours of LeMons?
Re: PTO on robots
This robot (2004) I remember, used a PTO to power their winch -- it was the thunderchickens.
Hard to notice, but that shaft that connects the two gearboxes is basically the winch, the pneumatics controlled the dogs which engaged/disengaged the winch.
Less Interest in Robots in the pits this year? sanddrag General Forum 36 11-06-2005 14:47
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Robots doing origami! RoboMom Math and Science 4 24-10-2004 19:42
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
