Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
Unread 24-06-2005, 13:18
WalterTheProf WalterTheProf is offline
WalterTheProf is on a distinguished road
RIS programming screen crashes
I'm using RIS 2.0 on a WIN XP machine. Periodically the system goes into a mode where I can’t attach blocks to other blocks and can’t modify block settings. The program appears to be totally corrupt and I have to re-create the entire program from scratch. Has anyone else had the same problem and if so, have you found a solution?
WalterTheProf
Unread 03-07-2005, 16:37
Re: RIS programming screen crashes
Well, it appears on researching the problem, I've solved it myself
The problem stems from situations in which discrepancies appear between the program files (.lsc) and the configuration file (.ini) for a particular vault. The macro definitions for each MyBlock code segment must be replicated and consistent in each of the files.
Problems arise when a user "opens" a program file (.lsc) containing at least one MyBlock code segment from a different vault and then saves it back into the currently open vault.
The fix is to not do those types of copies without copying the accompanying .ini file (MBFile.ini) along with the program file.
I don't know if this addresses every possible situation but it's taken care of the problem I'd been experiencing.
WalterTheProf
Unread 03-07-2005, 17:11
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Hm... sorry I missed this somehow when you first posted it.
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Organizing a programming team. scitobor 617 Programming 7 28-01-2005 19:18
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
