Go to Post Don't put any weight into the OPR. It's ugly and its momma dresses it funny. - wilsonmw04 [more]
Unread 25-06-2005, 04:39
tstName tstName is offline
tstName is an unknown quantity at this point
print alternate pdf document
I was trying to print a pdf file that was creat on the fly/saved in the server.The pdf file should not be displayed on the window. I used the method <link rel=Alternate type="application/pdf" media=print href="mydoc.pdf">. The print function invoking print dialog box and getting the printout with only blank pages. I beleve the print dialog box is not invoked from acrobat.this can be the issue for getting the blank pages.If I use a doc file or html page the print function will work fine.It will be a great help if any one can help me to solve this issue.
thanks in advance.
Unread 25-06-2005, 12:02
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: print alternate pdf document
This board is meant for FIRST Robotics, and this programming board deals primarily with C. Have you tried sitepoint?
http://www.mikesorrenti.com/
Unread 25-06-2005, 12:40
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
While the board isn't quite tailored for your needs, if the link Mike provided doesn't help you much, we have quite an assortment of talented website designers here, you might want to try PMing the great Brandon Martus himself (site admin here) or any number of people who freqent the web design subforums (you can find it under the 'ChiefDelphi Forums' link at the top, next to the logo and under the countdown bar). Hope you find your solution.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 26-06-2005, 06:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Yep... I don't know the answer, but for future reference, the webdesign section Matt is talking about is at:
http://www.chiefdelphi.com/forums/forumdisplay.php?f=64
I don't mean to gang up on you.
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 15-09-2005 15:20
PDF to word converter randys_2002 Computer Graphics 4 04-02-2005 21:07
Concerning pdf security buss Programming 4 06-01-2005 20:48
Print a different page than current page? KathieK Website Design/Showcase 9 24-08-2004 21:11
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
