Question About 4-Wheel Drive
I'm doing some robot designing in my free time over the summer, and I came to a question.
I'm making a 4-wheel drive chassis using the Kit transmission. To do this you can do it with two sprockets on the output of the gearbox, as seen in the attached picture. Now to make a very reliable drivetrain with this, I think the wheel's sprocket should be aligned with its corresponding sprocket on the output shaft of the gearbox. Doing this would need me to stagger the wheels one way or the other. The question is: Which way is most beneficial to stagger them? Front wheels inward and rear wheels outward or visa versa? Does it even make a difference? |
Re: Question About 4-Wheel Drive
Why not just put the sprocket on the other side of the wheel and keep the wheels pretty close to being inline? So you have two wheels with the sprocket outside and two with the sprocket inside.
http://www.firstrobotics.uwaterloo.c...etrains111.jpg |
You don't want your wheels to not be inline. Go with what Sanddrag said, or get two separate sprockets so that you can slide them on the output shaft to align them with the wheels, instead of being stuck with the double sprocket you've pictured.
What's shown in that illustration is not a 'double-sprocket', but two 21 tooth sprockets placed back to back. This arrangement was suggested for the 2005 Kitbot as an easy way of implementing four-wheel drive, but results in the wheels at one end being offset from those at the other. The picture Karthik linked to is effectively the same thing. The offset will vary with the length through bore of each sprocket.
The difficulty in customizing the spacing of chain on the provided transmissions comes simply from the limited length of the custom-made output shaft. The arrangement shown in the first illustration will probably do the best at getting the wheels as close to flush with one another as is possible without facing off some of one sprocket. I don't think you'll see much benefit in placing one set of wheels closer together over an another, as we probably spend equal amounts of time going in each direction throughout the course of a match. |
you could also use spacers between the wheel and sprocket to get them in line, if removing material off the hub isn't an option. |
You'd think it was designed that way... ![]() |
Don't forget to implement some type of chain adjustment or tensioning in your design. This year for time and simplicity we didn't do this and had one of the longer chains stretch allot. There was never time between matches to deal with it. We where lucky it didn't get bad enough to derail. Next year we will deal with it. A commercial chain tensioner isn't cheap. However it's not too hard to make your own.
#11
we made a longer output shaft thingy for out kit tranny if u can u should try that out and have fun!
#12
Thanks for all the input guys! I'm taking from this that inline is the best way to do things. However, this again poses a slight problem to me.
I should have mentioned that I won't be using those narrow wheels from the kit too. I'm going to be using something closer to 8" diameter, 2" wide pneumatic wheels. That is why I was having a rough time working with the two 21 tooth sprockets on the output shaft of the kit tranny. Their spacing doesn't quite allow for such a simple solution.Quote:
#13
Now if your comfortable with using smaller chain, which I know some people would yell at you never to use smaller chain in the drivetrain, but we succesfully use the set up I just described on our robot this year without a single problem. |
#14
My current design only left 6 inches in between the gearboxes. Whoops.
If I use only one CIM in each Kit tranny, would a set up as pictured in the attachment cause any problems? I'm limited in the dimensions of the chassis to very close to what it currently is. 22" wide, 24" long. So I can't make it wide enough to fit two CIMs in each tranny. |
#15
| Globe gear box | Pat Roche | Motors | 9 | 25-05-2004 22:50 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Clamping wheel hubs | sanddrag | Technical Discussion | 7 | 29-02-2004 00:20 |
| XP Hard Drive Space Question | Raven_Writer | Chit-Chat | 13 | 07-08-2003 16:38 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
