Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Unread 26-06-2005, 00:14
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question Drive-train shaft size
I did a search but didn't see what I am looking for at first glance.
I just recieved some samples from IGUS that are plastic bearings and such. Their website lists two FIRST teams who used them or other products in the last two years.
My question is two fold:
1. What size of shaft do you use on your drive-train if it is a roller chain sprocket type? We have a lot of stock in 5/8 with a keyway since the SkyWay Beadlock wheels have that bore type. I am not an ME so I don't feel solid on doing calculations but that seems to be extra beefy for FIRST class robots. Is 3/8 or 7/16 too weak?
2. If a robot only competes in one regional and then the championships, would the IGUS plastic bearings hold up to the abuse? Pillow block sets of steel are a big weight user. We are not at a fabrication level to be able to use flanged bearing set into the frame.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
229 Drive Train Adrienne E. Robot Showcase 32 09-09-2005 21:51
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: A proposed drive train idea. Elgin Clock Extra Discussion 10 16-01-2005 23:29
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
