Re: Spoiler: Could this be the new software for the FRC 2006?
PIC memory means you can use 16K ( 16000+ ) instructions. CoreChartFR includes the operating system for FRC, but CoreChart and CoreChart Professional are used on bare PIC chips to program real world PIC products. CoreChart is industry strength and it is used by engineers in defence and scientific research organisations because it is simple to get started and speeds up PIC applications. The dramatic reduction of "time to market" by CoreChart in PIC applications is critical to a business in the real world. As an example, one industrial product of ours is called an 'Intercooler Spay Controller' for turbo cars. It measures ( to 1% accuracy ) the duty cycle of the fluctuating car ignition injectors, and 2 temperatures, and 2 adjustment pots at a sample rate of 10,000 samples per second, then evaluate and output a high speed control signal as well as an updated LED display - all at the same time in real time on the car to cool the turbocharger so it does not overheat. This is no big deal. The big deal is that CoreChart enabled the software to be written using just 200 instructions ( which uses 400 bytes of memory ) on a 1k PIC chip running at 4MHz - which leaves lots of room for expansion. The product is getting rave reviews and is selling very well. |
I believe you are wrong on the real world thing from what i understand. Most of the time yes its learning the true language like C or whatever and flat out coding. But form what i understand there are places that use things like this all the time. In the REAL WORLD the is a easy way and a hard way. The easy way is a quick solution that you can't do much with and isn't very efficient. The hard way is a time consuming more efficient solution that you can do everything with. Most of the time in the real world you have to deal with the "hard way" a lot more. In the real world there are times where you know nothing at all and have to learn it on the spot, and most of the times are that way. But then there are other times when you can spend time and learn it well. This is an example. You have the time to use this program and learn some basic stuff from it. That will start you out. Then you can move on to the real code and stuff in between the first and second season. I believe if everyone does it this way there going to learn so much more and its going to stick in there brain so much better. Wouldn't you rather have someone learn it and have it stick with them rather than learn it and not stick with them? Anyway thats my $.02 worth. You can agree or disagree... i am just stating my opinion on how i think students would learn better. |
Bah, I'll stick with LabVIEW. Once I figured out how to control the RC with LabVIEW, I haven't looked at C code.
I've seen a demo of the software that VEX will use and it is very similar to this. It contains pre-written sub routines, but you can still write your own. The best part is that you do not need to know the language and still be able to generate code...
-Danny |
| [Official 2006 Game Design] OK, so YOU design the 2006 game... | dlavery | FRC Game Design | 29 | 08-01-2006 00:21 |
| **FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams | Goobergunch | FIRST E-Mail Blast Archive | 1 | 06-01-2005 09:29 |
| FRC Program State Frozen at Power-up | WillyC | Control System | 4 | 14-02-2004 18:05 |
