i wanna program the PIC18F8520 using another programming module which is called leaper-48 universal writer , it supports
PIC18F248(DIP) PIC18F248(SOP) PIC18F242(DIP) PIC18F242(SOP) PIC18F258(DIP) PIC18F258(SOP) PIC18F252(DIP) PIC18F252(SOP) PIC18F448(DIP) PIC18F448(PLCC) PIC18F442(DIP) PIC18F442(PLCC) PIC18F458(DIP) PIC18F458(PLCC) PIC18F452(DIP) PIC18F452(PLCC) PIC18LF242(DIP) PIC18LF242(SOP) PIC18LF248(DIP) PIC18LF248(SOP) PIC18LF252(DIP) PIC18LF252(SOP) PIC18LF258(DIP) PIC18LF258(SOP) PIC18LF442(DIP) PIC18LF442(PLCC) PIC18LF448(DIP) PIC18LF448(PLCC) PIC18LF452(DIP) PIC18LF452(PLCC) PIC18LF458(DIP) PIC18LF458(PLCC) but not the PIC18F8520 ,,, anyone think it will work on the PIC18f8520 of the Vex ?? |
Re: Using another module to program the Vex
In theory, it should, assuming you can interface the Vex kit and the LEAPER-48:
But, we don't completely know until you try. I say go ahead and try it, but I'm not responsible for any magic smoke. ![]() Last edited by Adam Richards : 28-06-2005 at 13:34. |
Are you planning to open up the vex module, desolder the PIC, and stick it in the programmer?
Realize also that while the 8520 is very similar to other PICs that programmer does support, the pinout and packaging is completely different. My answer is that it won't work without a significant time investment on your part. |
finally
i won't do it |
| how to build a VEX programming module | bblack7489 | FIRST Tech Challenge | 78 | 09-06-2011 16:03 |
| New Module system | Astronouth7303 | FIRST-related Organizations | 1 | 25-05-2005 17:30 |
| VEX Robotics | vexrobotics | FIRST Tech Challenge | 8 | 30-03-2005 23:25 |
| how to add steps in the provided encoder program for the edu | Zaramel2002 | Programming | 3 | 11-02-2004 08:35 |
