Go to Post There are times when all of us - myself included - need a virtual *poink* to the back of the head and someone to say "wake up and stop behaving like a three-year-old." - dlavery [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 29-06-2005, 00:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Pressure physics problems
When doing pressure physics problems like finding the pressure at the bottom of a swimming pool, do you have to add in the atmospheric pressure (101,325 Pa)? Or is pressure at the surface of the water typically taken to be zero?
EDIT: Atmospheric pressure is always taken into consideration in open containers. So in the swimming pool, yes you would add the atmospheric pressure to the pressure due to the depth of the water. In something like a dam, there is atmospheric pressure pressing on the top of the water and on the dry side of the dam, so it cancels out and does not need to be considered.
Unread 29-06-2005, 03:28
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Pressure physics problems
Sand,
Yes, atmospheric pressure is added in.
As a rough number, 1 atmosphere of pressure for each 33 feet of seawater (this is from my days as a scuba diver). So that at 100 feet of depth, the pressure is about 4 atmospheres. 1 liter of compressed air inhaled into the lungs at 100 feet will expand to 2 liters at 33 feet (2 atmospheres) and 4 liters of air at the surface (1 atmosphere). This is why it is absolutely essential for divers to constantly exhale during ascents and most "damage" from someone holding their breath while surfacing occurs in the last 10 feet...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 29-06-2005, 09:30
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Sanddrag,
Read the problem carefully and see what they are asking for. Pressure is generally reported two ways: 1) absolute pressure (i.e. add in atmospheric pressure); or 2) relative pressure (i.e. how much pressure above atmospheric).
Some problems require absolute pressure and some require relative. For example, tire pressure is relative pressure. Measuring pressure altitude with an altimeter is absolute pressure.
An ounce of perception is worth a pound of obscure.
Unread 29-06-2005, 11:43
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
BY the way, relative pressure is often refered to as "guage" pressure. It is often indicated in the unit notation by adding a "g" at the end. Psi and psig are not the same thing.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 30-06-2005, 15:07
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Originally Posted by Mike Betts
Sand,
Regards,
Mike
Mike -
Just a clarification. I seem to remember from my scuba (and a few other) classes) that overburden pressure increases of incompressible materials (e.g. pressure increases associated with increasing water depth) is linear. So in the example cited above, would it not be that 1 liter of compressed air at 100 feet will expand to 2 liters at 66 feet, and 3 liters at 33 feet, and 4 liters at the surface?
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 30-06-2005, 15:21
Ben Lauer's Avatar
Ben Lauer Ben Lauer is offline
Seshambeh Dareh Meyod
Ben Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond repute
I also have some scuba classes under the belt, and I agree with you Dave, but I believe that he may have just misstated. I think he may have just meant 33 ft higher than 100, or 66ft.
Unread 30-06-2005, 17:33
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Originally Posted by dlavery
Mike -
-dave
Dave,
I stand by my numbers...
1 atmosphere at sea level
2 atmospheres at 33 ft
3 atmospheres at 66 ft
4 atmospheres at 99 ft
PV=nRT and, assuming that nRT is a constant, P and V are complementary (have an inverse relationship). The pressure at 33 ft is 1/2 of the pressure at 99 ft so that the volume in 2X the volume at 99 ft. Likewise, the pressure at sea level is 1/4 of the pressure at 99 ft such that the volume at sea level will be 4X the volume at 99 ft and 2X the volume at 33 ft.
Like I said, the greatest danger is the last 10 feet. The esophagus is a very powerful muscle. Holding your breath in that last segment of an ascent will severely damage the lung tissues...
Regards,
Mike
Mike Betts
Unread 30-06-2005, 18:22
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Because I had two very learned men question my numbers, I went back to the physics book (see attachment).
Note that the plot of figure 17-4 (page 375 of Physics, 3rd edition, Halliday & Resnick, 1978) shows a linear (constant) P versus Y graph for depths below sea level.
Mike
Mike Betts
Unread 01-07-2005, 10:26
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Mike -
-dave
Pressure is linear with depth, but the volume of a given quantity of gas varies as the inverse of the pressure. 4/4 liter at 99 feet is 4/3 liter at 66 feet is 4/2 liter at 33 feet is 4/1 liter at the surface.
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
[ECDU]: pressure Michael Leicht FIRST-related Organizations 1 02-12-2004 16:38
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
