Go to Post “There are two ways to compete, one is to drag your opponent down, the other is to raise the bar and excel. Which do you think is more beneficial to you in the long run?” -- John Abele - Candice.E [more]
Unread 07-07-2005, 21:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Offseason Development - Let's see it!
Whose doing offseason development of robot mechanisms and stuff? Let's see it!
Unread 07-07-2005, 23:31
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Offseason Development - Let's see it!
Lets see...
Two speed, 9 fps low, 15 fps high. Shift on the fly. 6 motors. 8 lbs per drive train. Red anodized. Dimensions (without motors): 2" wide, 2.75" tall, 6.75" long. Chain output directly to wheels. Be afraid?
Aaahhh... yet another X51 product for a bay area team. Guess which one.
Nah, I'm just messing with you. Woodside, team 100, will be running this transmission soon.
Unread 07-07-2005, 23:46
Team Role: Teacher
Very good. Sure looks a heck of a lot smaller than our HexaMax we made this year. Can I get a top view?
Unread 07-07-2005, 23:50
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
We are just trying to do a basic Crab Drive. We hope to also be able to come up with a CVT design that isn't friction based and is light weight.
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 08-07-2005, 00:11
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
-2 speed Killer Bee style shifter...~10 fps high, ~5 fps low.
-Folded aluminum sideplates.
-6 wheel drive. (The center wheel is fixed to the output shaft of the gearbox, and the outside wheels are slaved off of it. I used 6 inch skyway wheels for the model because I had them on my computer, I don't know what will end up on the real thing.)
This is really just the basic idea of a design that I've been thinking about for awhile, I drew it on my car ride to DC for the fourth. I've still got a bunch of work to do, but it should be pretty lightweight, and cheap/easy to build. We'll probably build a prototype of it in the fall and use it for practice next season.
-Paul
Unread 08-07-2005, 00:57
As requested, an overhead view. Also a slightly tilted view so you can see all the gearing.
ID:	3506  Click image for larger version
Unread 08-07-2005, 01:32
Team Role: Teacher
Thanks for the view. Looks a little complicated. What's the output rpms? I assume you plan to have additional sprocket and chain reduction. Also, the low gear seems kind of close in speed to the high gear, no?
Last, do I see a couple gears whose shaft is supported only on one end?
Anyhow, it looks good. I hope it actually makes it onto a robot.
Unread 08-07-2005, 01:50
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Output RPMs are ~2000 in low, ~3300 in high. The gears are supported only one one end, sort of an unusual method but, the bearings are pressed into the gears and the shaft is pressed into the plates. Shaft collars hold the gears in place.
Unread 08-07-2005, 02:00
Team Role: Teacher
If the shafts are pressed into the plates (and straight) that should work fine. Your output speeds are quite high. Our HexaMAx was so large and heavy because we did all the reduction with gears in the box, and drove a 5.5" wheel straight off that. Our output speeds were theoretically about 600 rpm in high and 225 rpm in low.
Let's see some more designs!
Unread 08-07-2005, 02:16
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
No point in making it go, say 4 FPS when you can break traction at 10 as well. It seems as if recent games have turned more to speed anyways, and if you use that many motors, you can have speed and power even at such high speeds.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-07-2005, 05:54
24 Hours of LeMons?
we have a pretty big sprocket reduction, haha.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 09-07-2005, 01:23
Look for the first of these gearboxes at Cal Games 2005. And if we still have the same motors next year, a similar version for 2006 FRC.
Offseason Replays sanddrag Off-Season Events 11 02-08-2005 13:38
Baseball Offseason So far Corey Balint Chit-Chat 2 25-12-2004 13:48
People you want to meet in the offseason Greg Perkins Off-Season Events 18 16-05-2004 22:22
Development Program xxlshortys Team Organization 1 14-03-2004 12:33
