Go to Post Teams are overconfident every year. Honest evaluation of your capabilities with regard to your design strategy is a skill few teams have. - Chris is me [more]
Unread 14-07-2005, 00:21
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Cool creating your own HUD YAAAAY!!!
i bought a .75" x .5" x .5" color camera and a transmitter set. the idea behind it was that we could receive a wireless signal of exactly what our robot was doing even if it was across the field (i checked and i have a screen shot of the exact paragraph that allows it saved to my computer). we can even attach it to the arm and see exactly what were doing. anyway the problem of viewing the picture came up. i didn't want our driver to have to look down at the control board just to see what hes looking away from and LCD TV screens are expensive (about $200 a pop for a decent quality one if its a good deal). i thought about maybe using a LCD monitor but the converters were even more expensive than the TVs. so..... i thought back to the military and then i came up with HUD (Heads Up Display). the only problem is i couldn't find a screen small enough (at least one that fit my budget). i turned to the old faithful PC mod sites (these are actually better than robot sites if your looking for anything involving cool electrical components) and i came across the PUSTOM (i know really bad name ) 2.5" x 2" screen, they even have built in speakers and i could buy two of them for half the price ($45 each if you look hard enough) of a LCD screen. they use PAL (the UK voltage) but ultimately run fine on a 12 volt battery (which is good because you can't use a AC outlet on the field) unless of course you like electrical fires in which case by all means use a outlet. the video signal should be the same but ill let you know when i get it. Any way ive got one on order from Europe. I'm mounting it onto a helmet (a skater one i think. they look cooler ) and I'm including a pic and a link if your interested. I'm curious about your thoughts on the subject .
http://www.success-hk.com/pp/item_de...9-5AA7C5BDF348
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 14-07-2005, 00:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: creating your own HUD YAAAAY!!!
In the past I've always thought there was a rule that you could have a wireless camera if you clear it with FIRST and if it is not used to aid the driver during a match. I'd like to see the specific section of the rules that you believe allows it.
EDIT: I really thought there was a rule or Q/A disallowing this sort of thing but now that I look I can't find it. Does anyone know of a rule that specifically allows or disallows it (for the purpose of driver feedback)?
Unread 14-07-2005, 00:47
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
be careful using this at competitions though, there are very specific rules about broadcasting a signal during competitions,
the rule in question (for 2005 but will probably continue on because of the nature of the rule) is
<R94> Any decorations that involve broadcasting a signal to/from the robot, such as remote cameras, must
cleared with FIRST Engineering prior to use. Teams may not use 900 MHz camera systems.
that is located in section 5 of the 2005 FRC manual
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 14-07-2005, 00:59
yeah that would be the rule it does not say that drivers cant use it and i was carefull to get a transmitter that did not go on the 900 mega hertz range. however if you know of a rule from last year that says otherwise i would be very interested so as not to get a sudden nasty surprise.
Unread 14-07-2005, 01:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
There is a rule, or Q&A that very specifically says you cannot be receiving the feed from any camera systems on a robot, in the driver's station. If you were to do so, it no longer is a "non functional decoration" and must follow all the other rules.
It's fairly clear why you can't do this--it puts other teams at a competitive disadvantage. This is exactly the same as trying to use a walkie talkie/cell phone in the driver's station to communicate with someone with a better field of view up in the stands--it isn't allowed.
Even if nobody can find the specific rule, unless something major happens that the rules change next year (They probably won't) you won't be allowed to use your "HUD" in competition.
Here's the rule:
<R53> Custom Circuits may not: Be used for wireless communication, such as sending or receiving a signal to and/or from the alliance station
2001-2004: Team 100
2006-Present: Team 254
Unread 14-07-2005, 01:08
but thats to say that any sensor that transmits info to a driver cant be used. this is different than a person in the stands in that its a electrical equipment on the robot. also what would be the purpose of having a rule that alows camera that transmits a signal to be used but not allow you to recieve the signal? it gives no advantage since its off the shelf and can be used by anyone plus if you follow the extra component tree it fits in allowed electrical components.
Unread 14-07-2005, 01:10
Cory's Avatar
AKA: Cory McBride
See my above post for the quoted rule.
The purpose is that the feed from the camera goes to the AV guy, who can choose to put it on the big screen, or I assume one could be recording the feed to a computer/VHS tape/etc, at the AV station.
2001-2004: Team 100
Unread 14-07-2005, 01:12
which would be pointless because then the driver could see it and use it to his advantage! also look at my further commentary i added. also that seems impractical as the operator would have to be ABLE to pick up the signal my transmitter operates on 2400 megahertz
Unread 14-07-2005, 01:18
Cory's Avatar
AKA: Cory McBride
I'm not sure how you'd get an advantage in the situation I posed. If you're referring to the feed being on the screen, it's a non issue. In something like 14 matches in 2003 at Sacramento, we had a camera on our robot, and they probably showed the feed from it on the screen for less than 20 seconds total. Of that 20 seconds, it was all completely useless from a strategy standpoint. You couldn't even see anything well when it was on the screen.
Basically, I think a camera on the robot is utterly pointless, unless it's something high quality like a camcorder than you can watch your matches on after the fact, and even then it doesn't seem very useful, since it'll be jarred around constantly, probably breaking it, and taking up valuable weight.
2001-2004: Team 100
Unread 14-07-2005, 01:26
Team Role: Teacher
This reminds me of potentially (*key word: potentially*) the greatest robot design we had ever thought of. In 2004, we had seriously considered (even got to the points of determining how to actuate it and rough dimensions and soforth) a robot design that would sit in front of the opponent alliance station, telescope some poles out and drop some curtains to block the whole view. If they couldn't see, they couldn't score. Putting GP aside, it was the ultimate winning strategy. That is, until we remembered there was a video screen.
Anyway, the FIRST video screen is a legal and fair display because it is random between views of different robots and of the field. It doesn't keep any one view for very long at all.
Anyway, I don't think there is a good argument that a camera is not a "custom circuit". Maybe it doesn't seem like it and maybe it isn't but the "spirit of the rule" is that FIRST doesn't want any data coming to the drivers other than through the IFI radio modems.
the camera is a high resolution color camera that ive dropped ten feet with no problem except a scratch and this argument is pointless becuase the new set of rules hasnt come out and certian judges allow things that others would red flag. is all speculative. anyway if it gets flagged i just wont let the driver use it and it will still be fun. its just i dont see what problem it would cause since it isnt something anyone could do for $50 its not like a more powerfull motor it has no effect on your robots physical aspects.
Unread 14-07-2005, 01:30
Team Role: Teacher
You mean inspectors. Judges give awards, not enforce rules.
Anyhow, it would be cool if we were allowed to have such a thing because it would be more like robots in the real world that do more precision type tasks, but if the rules stay the way they have been, I'm thinking all you're going to be able to do is get a cool view for bystanders in the pit or stands, etc.
Unread 14-07-2005, 01:36
your right its the inspectors . i think that two things wil come into play.
one: the fact that their are two specific rules that overlap yet disagree with each other.
two: what inspector you get. our inspector allowed us to mount high intensity neon lights to the bottom of our bot. why: becuase they looked awsome. the problem: they could easily be used to "blind" other robots CMU cameras. it really depends on what the inspector thinks is an unfair modification and if someone on another team goes to the judges to complain.
Unread 14-07-2005, 01:39
Cory's Avatar
AKA: Cory McBride
Judges have nothing to do with enforcing the rules. Most of them don't even know the intricacies of the rules.
If you continue to develop this, I would hope you do it only for the sake of knowledge, and not to try and use it during competition. Any half decent inspector would never allow a robot with such a system on it to pass, and if they did, you're knowingly breaking the rules (and being "Un-GP" since everyone loves that phrase so much).
It has nothing to do with changing your robot's physical aspects. It presents a team with an unfair advantage. That's why a team can't bring out a step ladder for their coach to stand on and watch the match from about 6' higher (yeah, it's a safety hazard too). That's why you can't use any device to allow communication with any team members outside of the alliance station. There's plenty of rules like these that have no effect on the robot itself, but put other teams at a competitive disadvantage.
2001-2004: Team 100
  #15   Spotlight this post!
Unread 14-07-2005, 01:43
Tom Bottiglieri Tom Bottiglieri is offline
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Sometimes I wish I could put one of those full size cinematic film cameras on the robot. Then I could make some kind of feature film or something, but with my luck, it would be illegal.
creating curved planes stinger 3D Animation and Competition 7 26-02-2005 18:16
creating an array of images, help!! kris_krantz IT / Communications 3 04-01-2005 17:12
Creating and selling parts. Billfred General Forum 30 21-07-2004 00:18
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
