Go to Post How do You Chiefdelphi? :cool: - SpaceOsc [more]
Unread 07-16-2005, 09:24 AM
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Bash: permission denied - Script error
I was just setting up a simple script to sync my project files with the ones I have stored at OSC, where I run into this error:
This happens when I run my super-simple script of: (with the working part cut out)
Code:
#!/bin/bash
# setup a couple of variables
# call to scp using the variables abover
The part which cause's the error seems to be the simple interpreter line at the top. If I run bash manually through bash <name of my file>, it works fine. If I try to run it with just ./<name of my file>, I get the permission denied error. If I run it as root (IE, sudo ./<name of my file>), it works fine.
I did check /bin/bash just for giggles and it is executable by all. What could be causing this?
Unread 07-16-2005, 02:23 PM
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Rookie Year: 1999
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Bash: permission denied - Script error
Have you made the script executable by all? If not, try
Code:
chmod 777 nameofscript.sh
Unread 07-16-2005, 02:59 PM
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
The command chmod is needed, but 777 is always a bad idea, that gives everyone in the system full access to do whatever they want to the file. Not good chmod +x will add execution to its existing privileges, much more desirable.
chmod +x <name_of_file>
For example, if you as root create a file that does something simple, which you shouldn't do anyway but a lot of people do, and make it chmod'ed 777, any user could edit the file, and run it with root privileges via sudo, very messy.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 07-16-2005, 03:23 PM
Programming User
Hm. Well, it works now. Why does it have to be world executable? (I did have it executable for me.)
Thanks!
Unread 07-18-2005, 11:52 AM
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
What where the old permissions and what are the new ones?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
guidelines for modifying the linker script??? gnormhurst Programming 2 03-06-2005 02:03 AM
MPLink Error cloudago Programming 2 02-01-2005 11:00 PM
