Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 17-07-2005, 10:35
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Need help with Gyro = Analog Devices ADXRS150EB
I'm testing autonomous mode for IRI and "TURN" isn't working. Robot turns, but won't stop turning.
I'm working blind on this because our programmers were very capable, so I didn't stick my nose in the code, nor the control system. Also, I have no idea where the documentation for the gyro is.
What I do know is:
The code worked at the last regional, West Michigan.
A printf shows that Gyro_TImer() counts up as expected. However, Gyro_Angle() also counts up (but at a much slower rate than the timer) even though the robot was stationary. Is that normal? I expected to see the angle change only when the robot rotated.
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
