Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
Unread 23-07-2005, 23:23
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Arrow the best power regulator
what is the best power regulator for 5 volts to use with TTL? I know there are some good ones in the TO-220 package but idk what ones. any ideas? links?
Unread 24-07-2005, 00:13
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
Re: the best power regulator
Regulating down from what? You might want to check out Maxim ICs (www.maxim-ic.com) level shifters, nice stuff and they'll usually give you free samples.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 24-07-2005, 12:55
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Without more information as to exactly what your specifications are, the 7805 is the industry standard for TTL applications.
The 7805 is made by many manufacturers. Here is National's implementation.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 25-07-2005, 14:42
Hutch Hutch is offline
NOTAG
FRC #0461 (Westside Boiler Invasion)
Hutch will become famous soon enoughHutch will become famous soon enough
Ugh, sorry about the Puzzler post... Definitely left logged in and I didn't notice.
Anyhow, I'd say the best solution would be the regulator but if you don't have one, another (possibly cheaper) solution could be made with appropriately rated zener diodes.
EDIT: Found some decent diagrams and an explanation of how to do things the zener diode way, as well as how to do it with regulators (just keep hitting next slide):
http://www.mines.edu/Academic/course...t11/sld005.htm
Unread 27-07-2005, 01:30
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
down from 12 volts
Unread 27-07-2005, 02:08
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so if i used a 12 volt in put and get +5volts as an output then what do i use as ground?
Unread 27-07-2005, 09:54
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
On a 7805, and most regulators, the grounds are tied togeather. on a TO-220 package, the metal tab is usually internally connected to the ground as well (so make sure you don't short anything out on it).
Unread 28-07-2005, 00:22
NOTAG
Yep voltage is all relative, so it's output 5 volts relative to the wire the chip's ground is attached to.
Unread 28-07-2005, 21:04
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so i use the output ground as the input ground, and i have seen schematics of 7805's that hav non-polarized capacitors between the leads and i was wondering if those are neccessary, if they are what size should I use? and if not should i use somthing else
Unread 28-07-2005, 22:19
NOTAG
They aren't completely necessary, but they will prevent current spikes. When logic gates change states, they draw a lot of current (relatively), and the capacitors across the leads will keep the the current drawn from spiking as much.
Unread 29-07-2005, 18:48
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Yes, the caps are necessary. The stabilize the regulator and keep it from oscillating. Larger caps however, will help out with current spikes. Larger caps in addition to the small ones, not instead of.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 29-07-2005, 21:37
NOTAG
Hmmm I didn't recall them being necessary. But I at least am 99% sure that you can have the large ones instead of small ones since, after all, parallel capacitors are like one bigger capacitor (hooray for narrow, worthless AP physics knowledge ).
portable controls w/o using tether halomaster69 Control System 22 16-10-2005 02:18
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
