Old School machining question
This question is directed to the machinists... back when CNC wasn't so big.
Why can Volstro rotary mill heads only cut in a counterclockwise direction? The one I have been using cuts perfect counterclockwise, and cuts terribly clockwise, and not because of climb/conventional cutting differences. There is even an arrow to tell you that, but you can still cut clockwise. How come? |
Re: Old School machining question
i wonder if it has to do with either the motor or the drive train. im not fmiliar with the system so i cant talk in depth on it without being more familiar. ill look it up on google.
Maybe it has something to do with the way the belts are set up?
My one solution to improve performance besides getting a new motor, is to possibly add another gear somewhere to reverse the direction of the spin with out changing the current input into the motor. ------edit------ I guess I kind of worded it wrong earlier, to make my point a little clearer: 1.) Nothing is wrong with the Mill at all, its the motor 2.) The problem with motor is quite simple, first I'd reconmend reading this to understand how a motor works, or you'd probably have no clue what i'm talking about. 3.) What is happening is that the brush is being pushed offset by the direction of the current and by being pushed offset its no long running at the optimised speed. Read this for a more detailed explaination. Last edited by Conor Ryan : 30-07-2005 at 22:54. Reason: a tad clearer |
I know about the motor speed problems.
I was just thinking that the belts may have some sort of tensioner that might create a shake or bouncing effect in the spindle when run in the opposite direction. |
This has nothing to do with the mill itself, the mill works fine in both directions. The rotary mill head is something you put on the spindle itself, by clamping it to the quill. It has a standard R8 taper to recieve power from the mill, and it has two levers, cutter offset distance and rotation. This tool is a different approach to rotary table work.
Ive been following this thread because i myself have wondered about it. now it kind of makes sense.
Drew |
First of all, it seems that some people are wondering what this thing is; here are a few pictures, as well as the opportunity to buy one, if you're so inclined.*
Now, I don't personally have experience with this thing, but is it possible that some components inside are axially loaded, and that loading is dependent on the direction of rotation? (For example, helical gearing transmits an axial load to the shaft, and its direction depends on the direction of rotation of the driving gear.) That axial load could conceivably cause the behaviour described (by forcing the cutter into the workpiece in one direction, and upward into a thrust bearing in the other direction). *I have no relation to the seller! Last edited by Tristan Lall : 31-07-2005 at 14:41. |
#10
Thats exactly the one I'm using. I was using a brand new .250" end mill on it as well. Sadly the company has gone out of buisness, but it is useful anyway. As long as you rotate the head the right way.
| Indiana FIRST 2005 line up | Kyle Love | Regional Competitions | 4 | 04-11-2004 00:04 |
| What does the Chairman’s Award have to do with a robot contest? | Ed Sparks | Chairman's Award | 32 | 15-02-2004 13:39 |
| What do you feel about the growth of FIRST? | Ken Leung | General Forum | 35 | 03-05-2003 23:06 |
| How to keep a program running at a school which doesn't get it? | Jimmy | General Forum | 9 | 03-04-2003 10:08 |
| KSC awards | archiver | 1999 | 4 | 23-06-2002 21:59 |
