Go to Post Through 30 years of teaching I've heard the same refrain..."I love science, I love math but I can't stand my language classes". Well enough is enough. Get over it. - Mr.B [more]
Unread 01-08-2005, 14:09
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Jideco coupler?
I was wondering, How were we supposed to use the Jideco motor given to us this year? I just found the piece we had laser cut for us(we never did get around to using it). I just seems that generally FIRST is very good about giving us the important stuff so we don't have to fudge it if we don't choose to.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 01-08-2005, 14:14
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: Jideco coupler?
Team 330, beachbots have used that motor for the killer ramp they had. Take a look at their machine.
If I was to use the couplar, I would take few things into consideration. For example, what am I using it for, are there going to be a lot of torque involved for doing the job, is the plastic couplar good enough, or should I make a couplar out of aluminum, is it going to survive throughout the season. I would modify/add things to the couplar itself to make it work for what I want it to do.
Unread 01-08-2005, 15:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Jideco coupler?
There was no coupler included in the kit for the Jideco motor. This is part of the challenge. The plastic coupler included is for the Nippon Denso motor. Some teams have been able to find gears that sort of mesh with the Jideco (not perfectly but it works). Some teams make something that has a bore of the OD of the gear teeth, and then put set screws into the "valleys" of the teeth. Another option would be to do this but try filling the bore with JB weld (or similar compound) before placng it over the gear. Some teams go all out and carefully measure the gear and CNC their own coupler. This is probably the best route, but not all teams have that capability.
Unread 01-08-2005, 21:22
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Jideco coupler?
This is the perfect application for composite casting. Something that i haven't seen used hardly at all in First robotics. With some amine epoxy and some chopped or milled fiberglass or carbon fiber you can make some really tough stuff with casting techniques. We made a coupler for a lead screw this way.
Unread 02-08-2005, 17:31
FRC #0306 (CRT)
Re: Jideco coupler?
Actually, what we ended up doing was simply taking a free cad drawing of the motor, and simply cutting the part from that. If you have access to a laser or edm, this would be the best I thought.
-Sir Francis Bacon
-Albert Einstein
Pitch of Jideco Motor 781Co-Cap Motors 3 04-02-2005 20:37
Gear Coupling for Jideco Window Motor hayakuneko Motors 4 30-01-2005 18:35
Original application of Jideco motors Starman Motors 5 29-01-2005 18:55
2004 coupler bag boing Kit & Additional Hardware 0 16-01-2004 16:41
Jideco motors wanted for trade RobZeuge Technical Discussion 6 20-02-2002 16:44
