Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 06-08-2005, 00:08
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
BASIC stamp BS1
so today in the mail i finally got my BS1 from parallax and was wondering if any body had any idea for small project or things like that i could do with it to help me learn, i looked on parallax and that all requires knowledge of it and i am a begginner, i can make my way through programming simple things but the most i have done is making an LED blink repeatedly, haha
Unread 06-08-2005, 00:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: BASIC stamp BS1
Drive servos or modified-for-continuous-rotation servos. Or maybe you could drive an LCD. Or maybe you can make a balancing robot.
Parallax sells lots of neat stuff to go along with basic stamps. I'm not sure what all you can do with it just by itself, but if you add some stuff it can be very fun.
Unread 06-08-2005, 00:45
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: BASIC stamp BS1
i know that but i am talking bout things that dont cost like 50 -30$ each and that dont require high level programming
Unread 06-08-2005, 04:28
Hutch Hutch is offline
NOTAG
FRC #0461 (Westside Boiler Invasion)
Hutch will become famous soon enoughHutch will become famous soon enough
Re: BASIC stamp BS1
Something to make LED's dance is always kind of cool... Otherwise, things that drive servos are nifty (maybe make an arm or something?)
And PS, I responded to your PM ^___^.
Unread 07-08-2005, 17:57
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: BASIC stamp BS1
So get a PIC and a LCD and start messing with that. $2 for the PIC, $ 10 for the LCD, and $5 for a cheam JDM programmer. No high level programming either. You can do it in assembly, so its nice and low level
If you want simple, but still harder, make a LED chaser that changes speed when you push a button.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 07-08-2005, 20:51
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: BASIC stamp BS1
where do i get PIC's? and how do i programm them?
Unread 07-08-2005, 23:08
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: BASIC stamp BS1
First I have to mention that writing code for PICs (in assembly) isn't for everyone. It's a little daunting at first, but after awhile, it isn't that hard. You have to realize that it's very different from C, Java, or whatever other high level languages you use. You have to personally keep track of the memory that you use, it's hard to work with numbers larger than 8 bits, there's not much meaningful output while trying to debug... But, if you want to learn how computers work, it's a great way. PICs are also a cheap/small processor to use in whatever electronic project you have going. Keep all that in mind if you decide to take this on.
My favorite source for electronics is Mouser. You can get some PICs and parts to build yourself a programmer. The 16F84 seems to be the standard "newbie" chip. You can get a schematic for the JDM programmer here. IC-Prog is a nice loader. Unless you intend on buying a compiler, you'd have to write all your code in assembly. There's lots of tutorials online. The datasheets also make a nice reference manual. I think MPLAB will work to assemble the code, but I don't use it so I'm not 100% sure.
After you have some code, you assemble it and it spits out a hex file to be loaded onto your PIC. You put the PIC in the programmer, connect it to your computer and use your loader to write to the PIC. After that, it's ready to go.
If you decide to get some PICs, don't forget to buy some crystals and a voltage regulator. I made that mistake and had to place a second order.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 07-08-2005, 23:32
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: BASIC stamp BS1
Your going to need more then the stamp module. For experimenting you'll need either a work board or a solderless bread board. Look at these.
http://www.parallax.com/html_pages/p...ing_boards.asp
On the stamp web site look at the stamps in class tutorials. They start out with simple projects and progress to some good stuff. The basic stamp is well documented and supported but they're expensive. The basic stamps are also kind of limited. Since you are ready invested you might as well keep going with the stamp. When you want more power but the simplicity of programing in basic you might want to go to this chips. They use PIC 16 and 18 microcontrolers.
Kronos robotics
The Kronos basic allows in line assembler so you can take these chips pretty far. After your skills improve and you want to start playing more with robots, the vex kits provide allot of bang for the buck. Still the buy in is 400$.
Unread 08-08-2005, 00:20
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
Re: BASIC stamp BS1
PICs are nice, but I perfer AVRs, they can be programmed in C for free, or assembler, and they're just as easy to use as PICs, I'm currently using an AVR to drive a parallel LCD. You can either shell out the big cash (about $89) for the STK500 starter kit, which is very nice but overkill, or go for about $20 and get an AVR and the components to program it off the parallel port in your computer.
Check out these links for more info on programming AVRs.
http://www.uq.net.au/~zzdkeena/AVR/
http://www.lancos.com/prog.html
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 10-08-2005, 14:33
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: BASIC stamp BS1
thanks i was just looking on the wrong spot on parallax website
Basic Stamp Replacement Question Nate Smith Programming 4 13-07-2005 01:13
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
I Need Help with downloading Basic Stamp Program archiver 1999 2 23-06-2002 21:57
Is anyone using the BASIC Stamp Preprocessor? Greg Ross Programming 4 12-02-2002 12:24
