Go to Post I think applying Gracious Professionalism to strictly legal game play trivializes what is a much more important and fundamental FIRST concept. - jimfortytwo [more]
Unread 31-08-2005, 22:34
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
16F84 HELP!!!
i have a 16F84 assembled in a programming circuit but idk if the circuit will actually work cause i got it off the net and i cant figure out how to downlaod the code from my compiler to the PIC
Unread 01-09-2005, 00:00
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Re: 16F84 HELP!!!
That's not a whole lot of info to go on. Could you provide a link to the website you got this from, or a schematic of the programming circuit.
Unread 01-09-2005, 18:27
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: 16F84 HELP!!!
http://www.josepino.com/3/
Unread 01-09-2005, 20:47
fowlerm's Avatar
AKA: Matthew Fowler
Re: 16F84 HELP!!!
That programming circuit requires you to use an application called IC-Prog. Once you have the hex file from whatever development tools you are using you would use IC-Prog to flash the PIC.
Unread 01-09-2005, 20:57
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: 16F84 HELP!!!
what program can I use to get the hex file?
do you know of any circuts i can use that you know will work?
or any other applications i can use?
i got the .ASM file but not i have no way of getting the .HEX file
Unread 01-09-2005, 21:58
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: 16F84 HELP!!!
Calm down...
You make a .hex file every time you program the IFI controller. The linker actually creates the .hex from object code (.o files).
.asm files are either source code in assembler or a compiler generated intermediate file from a higher level language like C.
If you are not generating .hex files, either you have the integrated environment set up wrong or the linker had an error during its processing.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 01-09-2005, 23:15
fowlerm's Avatar
AKA: Matthew Fowler
Re: 16F84 HELP!!!
First off - do you have Microchip MPLAB installed?
If you don't then download and install it from here.
If so, then the simplest way to do this (assuming your code is only one assembly file) is to do the following:
1) Open the assembly source file in MPLAB
2) On the MPLAB menubar choose Configure->Select Device...
3) In the dialog that comes up choose the PIC16F84 or PIC16F84A depending upon what chip you have.
4) On the MPLAB menubar choose Project->Quickbuild
MPLAB will launch the assembler (MPASM) and will build a hex file in the same directory as your assembly source file. Then you can use IC-Prog to flash the PIC with your newly created hex file.
Unread 02-09-2005, 12:32
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: 16F84 HELP!!!
i am having problems using IC-PROG because everytime i go to flash the PIC it freezes, it comes up with an error message thats says
"if you were in the middle of something, your information might be lost"
then IC-PROG just freezes
and yes i have MPLAB installed
also i need a way to get a .ASM file because they way i thought would work didn't
Unread 02-09-2005, 14:50
fowlerm's Avatar
AKA: Matthew Fowler
Re: 16F84 HELP!!!
I'm not exactly sure what you mean by this. Correct me if I'm wrong, but from what I understood from your other posts was that you had written the code in assembly.
If this is not the case, how were you going to get the assembly file?
If you could tell me exactly what your development setup is, it would help alot. Like what your MPLAB version is and what compiler you are using (if any).
Unread 02-09-2005, 17:28
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: 16F84 HELP!!!
i wrote the code in c but i need to convert it to assembly, and i am just using mplabs and ic-prog
Unread 02-09-2005, 17:39
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: 16F84 HELP!!!
You can't do that with a 16F84 without using a 3rd party compilier. We told you that in another thread. The C18 compiler does not compile for 16F's, only 17's and 18's. You have to write the code in assembly by hand or buy a 3rd party compilier to use it with a 16F84, as you were told in another thread.
Unread 02-09-2005, 18:08
fowlerm's Avatar
AKA: Matthew Fowler
Re: 16F84 HELP!!!
HI-TECH Software has a free compiler called PICC Lite that targets PICs commonly used by hobbyists, including the PIC16F84(A). You have to register with HI-TECH, but the compiler is free. The compiler integrates with MPLAB, and is very easy to get up and running.
Unread 03-09-2005, 18:14
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: 16F84 HELP!!!
i WAS TRYING to use a 3rd party compiler to assemble it but it didnt work, that is why i asked if anybody knew how i cud get it from c to assembly
