Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 05-09-2005, 13:06
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Analog-to-Digital Converter Code
For those who might be interested, I've just posted new analog-to-digital converter interface code for IFIs robot controllers. A few advantages of using this software include parallel, non-blocking operation of the ADC hardware, precise control over the sampling period, which is important for signal processing and control applications and the ability to make measurements with greater precision using a technique called oversampling. The code can be found here: http://kevin.org/frc. As always, if you find a bug in the code or a problem with the documentation, please let me know.
-Kevin
Here's the readme file:
Code:
The source code in adc.c/.h contains software to setup and run
your robot controllers analog-to-digital converter in the
background. A few advantages of using this software include
processing and control applications and the ability to make more
precise measurements using oversampling. Number of channels,
sample rate and oversampling parameters can be changed by
editing adc.h and re-compiling.
This software makes the assumption that when it's running, it
solely controls the analog to digital conversion hardware.
WARNING: The higher sampling rates can place quite a load on
the robot controllers CPU. If you get the red-light-of-death
or notice any general wackiness in the operation of your
robot, first try a lower sampling rate to determine if this
is the problem. In general, you should select the lowest
sampling rate that meets your performance criteria.
This source code will work with the Robovation (A/K/A EDU-RC)
robot controller and the FIRST Robotics robot controller.
The included project files were built with MPLAB version 7.20.
If your version of MPLAB complains about the project version,
the best thing to do is just create a new project with MPLAB's
project wizard. Include every file except: FRC_alltimers.lib
and ifi_alltimers.lib and you should be able to build the code.
Eight things must be done before this software will work
correctly with your robot controller:
1) A #include statement for the adc.h header file must be
included at the beginning of each source file that calls the
functions in adc.c. The statement should look like this:
#include "adc.h".
2) Initialize_ADC() must be called from user_routines.c/
User_Initialization().
3) On the EDU-RC, all analog inputs must be configured as
INPUTs in user_routines.c/User_Initialization().
4) The call to Set_Number_of_Analog_Channels() must be removed
or commented out in user_routines.c/User_Initialization().
5) The timer 2 interrupt handler, Timer_2_Int_Handler(), and
ADC interrupt handler, ADC_Int_Handler(), must be installed in
User_Routines_Fast.c/InterruptHandlerLow(). See the included
copy of User_Routines_Fast.c to see how this is done.
6) Define the number of analog channels that you'd like this
software to track by opening adc.h and following the embedded
instructions above #define NUM_ADC_CHANNELS.
7) For advanced users, analog channels can be oversampled to
decrease noise and gain resolution in your analog measurements.
The oversampling ratio can be changed from the default x16
by commenting-out the line #define ADC_SAMPLES_PER_UPDATE_16
found in adc.h and then removing the // from in front of one
of the other options. Measurement range and resolution can be
determined from this table:
ADC Samples Effective
Averaged Bits of Measurement Voltage
Per Update Resolution Range Per Bit
___________ __________ ___________ _________
1 10 0-1023 4.88 mV
2 10 0-1023 4.88 mV
4 11 0-2047 2.44 mV
8 11 0-2047 2.44 mV
16 12 0-4095 1.22 mV
32 12 0-4095 1.22 mV
64 13 0-8191 610 uV
128 13 0-8191 610 uV
256 14 0-16383 305 uV
8) Finally, pick the master sample rate by selecting one of the available rates found in adc.h. The update rate can be determined using this formula: Update Rate = Sample Rate / (Samples Per Update * Number Of Channels) **************************************************************** Here's a description of the functions in adc.c: Get_ADC_Result_Count() This function returns an unsigned char containing the number of ADC updates generated since Reset_ADC_Result_Count() or Initialize_ADC() were called. Use this function to determine when fresh analog to digital conversion data is ready. Reset_ADC_Result_Count() This function can be called to reset the ADC update counter to zero. Get_ADC_Result() This function can be called to retreive analog to digital conversion results. Call this function with an unsigned char containing the ADC channel you'd like data from. This function will return an unsigned int with the last conversion result. Convert_ADC_to_mV() This function converts the value generated by the ADC to millivolts. Initialize_ADC() This function initializes the ADC hardware and software. It should be called from user_routines.c/User_Initialization(). Once called, analog to digital conversions will automatically take place in the background. Disable_ADC() This function disables the ADC hardware and software. To minimize the load on the microcontroller, this function should be called when the ADC functionality is no longer needed. Initialize_Timer_2() This function initializes and starts timer 2, which initiates a new analog to digital conversion each time the timer 2 interrupt service routine is called. This is called by Initialize_ADC() above and shouldn't be called directly. Disable_Timer_2() This function is called from Disable_ADC() to disable timer 2 and shouldn't be called directly. Timer_2_Int_Handler() This function is automatically called when timer 2 causes an interrupt and shouldn't be called directly. New analog to digital conversions are initiated from this function. ADC_Int_Handler() This function is automatically called when new analog to digital conversion data is ready and shouldn't be called directly.
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Last edited by Kevin Watson : 05-09-2005 at 14:22. Reason: Added adc_readme.txt text
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
