pic: My wheel/leg design
Re: pic: My wheel/leg design
GREAT!
Just a thought ...you'll need some pretty sophiticated stuff to be able to stop the robot. In the show the robot kinda turn and difts to a stop ![]() |
From a more practical standpoint, if you make that entire shaft spin, you'll be putting a terribly large load on the bearings and shaft. Ball bearings are intended to support mostly radial loads. With your current design, the shaft bearing at the top would see a large thrust load, which would drastically shorten the bearing's life if you don't over-spec the bearing by a lot. Also, keep in mind that flexible shafts aren't going to transmit much torque.
i think a simple doublewishbone idea of a suspension would work just as well and simpler.
Just wondering but, could you explain how it works? It look pretty cool
![]() Last edited by Cpt_Dave_Lister : 02-10-2005 at 23:57. |
Well the general idea is that their are four legs and the sit out at an angle from the robot. The entire leg can rotate on that gear (more symbolic of where it pivots then anything else). Also the rod is attached to that square coupler by a ball bearing and rotates. When it rotates the half sphere at the bottom acts like a wheel. Its just a conceptual design right now and not really possible due to the limits of last years kit but its a future plan. Not only could it have simple walking but the legs could start facing up and fold down to add significantly to the height of a robot. Basically I'm trying to come up with a simple walking robot that doesn't have the disadvantages of speed that most walking robots posses.
As mentioned its got a few engineering hurdles it needs to overcome but if i don't use something like this in FIRST then ill definitely do it privately because the idea has been bouncing around my head for quite some time i just never really developed it until now. |
In what way does this "walk"? Iit just a wheel at the end of a shaft? Or can it also swing the shaft some how...
It "walks" by whipping around that large gear the shaft bracket is attached to. Mind you, it'd walk better if the leg moved in and out as well as around or something similar. Perhaps instead of starting from scratch on both counts, you should find some simple leg joints that work for people and then figure out how to put wheels on them?
#10
I you want to see a ton of different walking robot designs, check out this page. (You'll have to scroll down a bit.) I know that these are Lego creations, but the principles behind the walking robots can be adapted to a larger scale. IMHO, I would think that instead of rotating the entire leg around, do as Kevin Sevcik suggested, and make the legs go up and down, instead of in circles. Similar to this picture:
I know that it wouldn't be able to go up stairs, but it would have much less stress on the shafts. Also, I am curious. What is the size of your leg? ![]() |
#12
Finally getting around to answering this... You could obviate the need for tons of extra motors, pulleys, chains, flexible shafts, etc by going with a large, well designed leg, and then putting a motor/gear case/wheel assembly on the end of it. Using FIRST parts, it'd be some sort of sturdy leg system with a Nothin'-But-Dewalts motor assembly attached to a wheel at the end of the leg. There are trade-offs, obviously. This makes your leg much heavier. But on the plus side, electricity is an awful lot easier to bend around corners than mechanical rotation. Last edited by Kevin Sevcik : 07-10-2005 at 09:48. |
#14
Wait would it still have both leg and wheel motion? If you can, add a picture of the design. Thanks.
| pic: my more specific design | mechanicalbrain | Robot Showcase | 6 | 29-06-2005 22:39 |
| Team 862'sEDUbot Design competition | GhostInTheShell | Off-Season Events | 4 | 26-06-2005 18:10 |
| Programming a 2nd PIC | ImmortalAres | Programming | 8 | 16-06-2005 12:13 |
| pic: 1305 Frame design with trannies | CD47-Bot | Robot Showcase | 19 | 25-09-2004 01:13 |
| Ok, so YOU design the 2003 game... | dlavery | General Forum | 157 | 07-01-2003 23:55 |
