Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
Unread 18-10-2005, 08:33
crimsonsamuri crimsonsamuri is offline
FTC #0047
crimsonsamuri is an unknown quantity at this point
C programing help needed
anyone out there know how to flow chart C if so send some info on the subject because I am making a program for the robot atomous mode.
Unread 18-10-2005, 09:48
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: C programing help needed
A flow chart is a tool commonly used by programmers to illustrate and determine the logic their program will follow, before any real code is written.
Flowcharting Basics
If you decide to use a flowchart, (you should always plan your code, whether it be with a flowchart or some other clever tool) you can make the process easier and use office software to help you create it.
I use Microsoft Visio.
If you are just starting to learn C, and working primarily with the robot, I suggest taking a look at these presentations, along with the programming forums here on Chief Delphi.
Unread 18-10-2005, 11:01
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
its pretty good
also its useful for doing electronic circuits
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 18-10-2005, 16:39
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
I use Umbrello. Sorry, Linux only.
Unread 19-10-2005, 04:32
BorisTheBlade's Avatar
BorisTheBlade BorisTheBlade is offline
lead programmer 2004
AKA: Dane
FRC #1351 (TKO)
BorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura about
Send a message via AIM to BorisTheBlade
if your using windows try using microsoft visio. yea its microsoft but its a powerfull tool not only for flow charting but also for structure charting anthoer usefull programming technique
Team 1351 TKO Robotics (click for our website)
2007 sacramento regional Johnson & Johnson Sportsmanship Award winners
2007 CAL Games Finalists
White Paper Discuss: All I Ever Needed to Know I learned in FIRST poster CD47-Bot Extra Discussion 5 28-03-2005 15:44
Help needed for getting started! chantilly_team Programming 4 27-10-2004 08:29
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
Battlecry 3 volunteers needed? Hymnson Off-Season Events 4 02-06-2002 12:38
Inventor 5.0 help needed Larry Barello Inventor 4 27-01-2002 10:54
