Go to Post This slow-motion intro... Canada is rubbing their match cycle efficiency in our faces :( - PayneTrain [more]
Unread 20-10-2005, 23:01
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Victor 884 won't go forward
Hi,
We have an 884 that came with this year's kit that only works in reverse. When we send it a nice 254, the Victor LED does turn green but the voltage is 0 V.
We discovered this problem on the ship day (sure, when else?), when our arm was only going down. We then noticed the fan had stopped and proceeded to replace the Victor.
Today I tested it again, hoping that the long months of dust gathering would have done it some good. Sure didn't.
So we pried it open and there was nothing wrong, apparently. No smell, no burn marks, nothing. We heated the MOSFETs a bit to see if it might have been a problem of cold solder joint, but it didn't help.
Any ideas?
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 20-10-2005, 23:16
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Victor 884 won't go forward
YIKES! how did you heat the Mosfets?
one possibility is the Victor lost its calibration. I think there is a way to restore the factory default setting, and I know it is possible to re-calibrate it (pushing the tiny recessed button while it is connected to the control system, pushing the joystick all the way forwards, then all the way back.... Its in the manual for the control system (or the Victor data sheet).
There are several Mosfets for each leg of the H bridge in the Victor. I find it hard to believe all the 'forward' mosfets could have burned out. But it is possible the controlling electronics in the Victor have failed.
Parts do fail. We use to staple all our failed parts to the wall in our Sparky area. After a few years we had quite a collection on the 'wall of death'.
Unread 20-10-2005, 23:58
Manoel's Avatar
Rookie Year: 2000
Yes, we did calibrate the Victor to the factory default.
We have a lot of dead Victors (wrap it up in electrical tape to identify!), but this one has such a bizarre failure that we haven't labeled it dead... yet.
Mentor
Brazilian Machine
Team # 383
Unread 21-10-2005, 00:08
If you have an oscilloscope, and could get your hands on the schematic for the Victor, it would be interesting to take it all apart and see where the 'forward' signal is dissapearing
Ive never tried to fix a burned out victor. But if you have a couple maybe some clever student could build one or two good ones from the dead pile?
Unread 21-10-2005, 00:33
Manoel's Avatar
Rookie Year: 2000
Well, if I could get my hands on the schematic I'd be a very rich man
Unfortunately we do not have a scope, and I don't know if it would be very helpful. Pretty much everything is SMD and the board not only has a mask that hides the wire traces, it also has some weird silicone covering that makes it even harder.
Since it is our only broken 884 (though the board is marked 883 revision F), I'll take a look at the (lots) of 883s we have to see if they share the same MOSFETs.
Thanks for the advice,
Mentor
Brazilian Machine
Team # 383
Unread 21-10-2005, 00:55
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Originally Posted by Manoel
...We have a lot of dead Victors...
Manoel,
Be advised that I have been mentoring Team 177 since 1995 (before IFI and the Victor existed). We use between 7 and 11 Victors per robot and some years we build two robots.
We have only failed two Victors in all that time. Both failed due to metal shavings falling into the FET heat sink assemblies (beneath the fan).
If I were you I would re-look at the "dead" Victors during the off season...
My students have reported many "failed" parts that were not failed. Bad or loose PWM connections are the primary electrical reason for these reported "failures". Other "causes" have been mechanical binding of the motor, software and cables/wires going where they shouldn't.
In my humble opinion, the Victor is a highly reliable part.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 21-10-2005, 01:10
Manoel's Avatar
Rookie Year: 2000
Originally Posted by Mike Betts
Manoel,
Regards,
Mike
Mike,
Thanks for your advice, but we are very thorough when analyzing a Victor (as I pointed out in my description - I'm not sure there's anything else we can test on this one) and labeling it defective.
I agree that they are very reliable items, but we have had some tough luck before.
I remember only ONE Victor blowing up because of metal shavings. We have some old Victors (the one with stickers on the bottom with calibration procedures), some really old Victors (the ones that required external capacitors) that simply refuse to work. We have received TWO Victors from the Kit that were DOA - the cost and time to send it back turned them into fancy paper weights.
We also have had one Victor blow up straight from the box, mounted in a Lexan board with absolutely no metal shavings.
What intrigues me is this weird kind of failure, refusing to work forward. I had never seen something like that and don't recall ever seeing it on CD.
Again, I'm open to suggestions.
Mentor
Brazilian Machine
Team # 383
Unread 21-10-2005, 08:44
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I also second the statement about the fact that Victors seem to be extremely reliable. I've been working with them since they existed and haven't seen too many fail. I should say that there's a cavaet with the extremely reliable line: it was that way until this year.
Perhaps it was simply coincidence, but it seems that the quality of IFI products decreased this year. I did see a speed controller with exactly the same failure characteristics you're noticing. This was at a competition and we asked the IFI personell about it; they thought that some of the FETs were dead. There weren't any metal shavings or anything else to indicate why it had failed. I think you just have a dead speed controller and need to swap in a replacement.
Matt
Unread 21-10-2005, 09:28
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
I second the notion of replacing FETS. We have done this and resurrected a few Victors (all 883s).
But... that seems to not be your problem. The Victors up here in North America work well. Yours give you problems. Since you are located in the southern hemisphere, maybe you should mount them upside down.
Hey, you said you were open for suggestions.
Andy B.
Unread 21-10-2005, 17:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
I am looking at a Victor with exactly the same problem you describe.
We were noodling around driving things we probably should be driving with a Victor (I am ashamed to say I was using it a load for a charge circuit for batteries -- Not exactly the design usage) something when pop and no more reverse.
Anyway, it is hard, but not impossible to fry an entire leg a Victor's H bridge*.
Joe J.
*Actually, it is quite easy to toast the MOSFETS in a typical H-bridge (I have a PILE of those next to the bad Victor). It is a tribute to Tony & Bob & the rest of the IFI Gang that they have wrapped these fragile jewels in such a way as to make it quite difficult for us to destroy.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 22-10-2005, 12:52
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
My team has a Victor with the same failure characteristics also, but we've determined the cause to be driving the motor the victor was connected to manually.
In Atlanta,, a student got metal shavings in one of our Victors for the drive, and it blew out next power up. We were left with 3 functioning and a few minutes until our next match. So we decided to go from 4-motor/2-wheel to 2-motor/2-wheel. But in our rush we only disconnected the PWMs to the corresponding Victor on the other side of the drive. After the match that Victor failed to work. We think it's because the disconnected motor was manually spun by transmission (it was geared to a working CIM) and the reverse current flow blew out the forward half of the H-bridge. It's the only logical problem we can find, and seeing as how 2 motors geared together was considerably more popular this year, combined with loose PWM cables, that could explain the apparent rise in Victor failures.
I think.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 22-10-2005, 13:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We've pushed our robot on the ground and spun the motors sometimes generating enough current and voltage to make all the lights come on and the fans spin. So, I know the electronics can tolerate a little bit of this. But a whole matches worth I guess not.
So my two questions:
Is is really bad to backdrive motors in turning them into generators in the FRC electrical system and why?
How long can you do this for without causing any damage?
Unread 22-10-2005, 14:47
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
You know, I've actually been trying to figure out why backdriving the motors generates current to turn the system on. I haven't been able to figure it out though. The MOSFETs have diodes, but they're reverse biased, so any current going through them would be in the wrong direction. The other thing is that at some point, the power has to get to the RC to turn it on.
But to answer your second question, we had someone pushing it through a parking lot one time. By the time it got to it's storage location, it had turned itself on. The backup battery was maintaining the RC. It also smelled funny, like burning electronics. But, it still worked fine. I wouldn't advise doing it though.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 22-10-2005, 22:50
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Originally Posted by sciguy125
...The MOSFETs have diodes, but they're reverse biased, so any current going through them would be in the wrong direction. ...
But there are 4 of them in an H configuration. These 4 diodes end up working like a rectifier bridge; no mater which way the motors generate electricity, the diodes funnel + voltage to the +batt and the - voltage to the -batt (a.k.a. ground).
This is why the lights come on no matter which way you turn the wheels.
Joe J.
Mentor
Team #88, TJ2
Making a forward only speed control reverse sanddrag Electrical 7 12-12-2003 07:19
What CD's are you looking forward to? Jay W. Chit-Chat 12 31-08-2003 01:39
forward reverse on drill motor PDonovan Motors 2 03-02-2003 11:11
Which teams are you looking forward to their robot? Ken Leung General Forum 17 14-02-2002 19:59
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
