Go to Post Aaaah - interpersonal dynamics - the root of most problems on most teams. - UCGL_Guy [more]
Unread 21-10-2005, 09:30
Sepsis900's Avatar
Happy Birthday! Sepsis900 Sepsis900 is offline
professional...er...I build robots
AKA: Alex Bachmanov
FRC #0321 (Robolancers)
Team Role: Leadership
Sepsis900 is an unknown quantity at this point
Send a message via AIM to Sepsis900 Send a message via Yahoo to Sepsis900
Experimental Ball Drive
Howdy All. My team is planning on trying out an idea called a "ball-drive" for this year's competition, and i wanted to utilize this forum's engineering expertise, to see if this can somehow be made into a viable drive system, or if this is just a dumb idea that will embarass us at regionals. The thing is designed to work like a mouse-ball, except instead of providing input (like a mouse does) based on the ball's movement, the ball is driven by several wheels (probably small omni-wheels), that rotate it around the X, Y, and Z axes.
The frame will be circular for this application, and will have 5 caster wheels around the edge. The ball itself will be a hollow metal ball coated in either rubber or another grippy material. It ought to look something like the picture attached. (http://www.chiefdelphi.com/forums/at...tid=3629&stc=1 )
My opinion is that the drive is not the best idea, and here's why:
-The area of contact between the ball and the floor is very small, leading to the problems of:
---movement. If we accelerate too fast, the ball will start slipping, and our traction disappears
---rotation. turning 120 pounds of robot with such a small area of contact (directly in the center) is difficult at best and impossible at worst
---carpets. If the floor of the FIRST arena is made of carpet and the ball of rubber, you get almost no traction at all (because the carpet moves under the ball), which is compounded by the problems listed above. (can be remedied by gratuitous use of velcro)
-The robot won't be able to go up inclines. If the front end is on an incline and the back end on the floor, the ball is off the ground and not providing power.
-If the center of gravity is not directly over the area of contact with the floor, there is more thrust on one side of the COG than the other, which leads to unwanted spin.
The use of a fast, maneuverable robot was usually advantageous in past competitions, and we're shooting for that this year. The team suggested the ball because it has the potential of providing multi-directional thrust and rotation at the same time, like a holonomic drive. But the idea of a single ball is a lot simpler than everything involved in said holonomic drive.
We're talking to professional engineers on what their opinion of the ball-drive is, and considering a lot of the problems and benefits ourselves, but any advice or opinions you guys can contribute will be greatly appreciated!
Thanks!
Unread 21-10-2005, 09:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Experimental Ball Drive
Not legally it can't. At least not in prior years.
Anyway, it has been done before and worked remarkably well http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Unread 21-10-2005, 10:27
Sepsis900's Avatar
AKA: Alex Bachmanov
Interesting. That's a pretty neat design. I'll make sure to post the pictures on our team forum, thanks!
Unread 21-10-2005, 10:37
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
Rookie Year: 2000
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Ahh yes, the ball drive. I would search the forums here for "technokat ball drive".
Here are some threads that you may be interested in.
http://www.chiefdelphi.com/forums/sh...t+ball+dr ive
http://www.chiefdelphi.com/forums/se...earchid=493678
Mark Koors was the engineer that designed the ball drive. He doesn't post too often, but if you have any questions that you cannot answer from the above threads [which are full of information] you may be able to give Andy Baker a shout. If you want any additional images, you may be able to get ahold of my brother, Clark Gilbert . Most of the past Technokat images are from him, so I'm sure he has quite a few saved.
Unread 21-10-2005, 13:06
Team Role: Teacher
I'm not an expert on patent laws but make sure whatever you do doesn't cause any problems because the T-kats bot/design is patented.
Unread 21-10-2005, 13:59
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
This just means that someone besides Delphi should not use this design with the intent of making money from it. FIRST teams can still use this idea to create a drive base (I have already PM'ed Sepsis900 to offer advice). Delphi management simply wanted to protect their rights by filing for a patent covering this specific design, not to keep other FIRST teams from using it.
Further development is encouraged and FIRST teams could make this drive system better.
If someone takes this idea and develops a more elegant iteration to improve performance, then they will have an invention of their own. Then, they can create a patent and seek commercial advantages.
Andy B.
Unread 21-10-2005, 14:05
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Pictures
I'm in the process of uploading numerous pictures and one small video. I'll add the link when I'm done.
Index of files:
http://web.ics.purdue.edu/~cagilber/files/BallDrive/
Movie:
http://web.ics.purdue.edu/~cagilber/...e/DSCF1884.AVI
Prototype from around January 2003.
http://web.ics.purdue.edu/~cagilber/...ive/Prototype/
Purdue Alumni
Cummins, Inc.
Unread 21-10-2005, 14:45
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
This thread might also intrest you. It is more about creating a bot that is compleatly round. Similer, but I think more interesting and harder
http://www.chiefdelphi.com/forums/sh...ad.php?t=31115
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 21-10-2005, 14:49
Sepsis900's Avatar
AKA: Alex Bachmanov
The 2-ball (snicker) system is way better than our original idea. More stability, and just as maneuverable. Here's what Andy said was the main disadvantage of the drive:
The main disadvantage is what I will try to describe as a "second level of traction loss". Consider a wheeled-driven robot. If the robot is pushing against an immovable object, then the wheels will most likely spin (the wheel torque results in a tangental wheel force that is lower than the robot weight x coefficient of friction, but that is a lesson for another day). When these wheels spin, the robot has lost its ability to move because of a loss of wheel traction with the carpet. In a ball drive system, there are two points of contact and EITHER could lose their traction. The small wheel can lose its traction with the ball, and the ball could lose its traction with the floor. The opportunity for traction loss in two places results increased efficiency losses in this style of drive system.
I think the wheel-to-ball traction loss can probably be remedied by using larger rubber wheels, which would provide a bigger contact area between the wheel and the ball, while still only giving the ball reasonably small resistance while rotating around the point of contact (the other wheel turning would rotate the wheel along this axis). The ball-to-ground problem could be fixed by using a tread pattern on the ball, which is simple: it only involves epoxying mountain-bike-like-tread-patterned rubber sections instead of smooth ones. Comments?
[WHUMP]
"...That's a feature. Our robot plays dead."
[CLUNK]
"The arm just fell off"
"That's another feature!"
Unread 21-10-2005, 15:09
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Believe me, Andy knows his stuff ...
While you can increase your traction (coefficient of friction) by selecting various materials and tread patterns/orientation, you cannot escape the laws of physics. You will either lose traction at some point, or burn out your motor(s). I believe Andy's point was that you double the number of locations where you have to consider that issue (in his ball-drive design).
It certainly would be an interesting project to tackle though. Please keep us posted on your progress.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 21-10-2005, 15:19
Sepsis900's Avatar
AKA: Alex Bachmanov
of course, losing traction or burning out your motors is a potential problem with any drive system. I'm just trying to delay the "losing traction" part, since that seems to be the major problem Andy pointed out
[WHUMP]
[CLUNK]
Unread 21-10-2005, 17:32
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
i know ball drives are all cool and holonomic but whats wrong with using a "Traditional" omniwheel setup? so much simpler and less places where friction is needed to drive stuff,
Unread 22-10-2005, 05:32
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Speaking of ball drive... Last I heard, Andy Baker has still yet to see the vehicles in I-Robot!
Help me out here, If he still hasn't seen the cars/trucks etc in the movie and their ball drive propulsions systems, please bug him until he does.
This post should fill my quota this month.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 22-10-2005, 12:04
Rookie Year: 1998
The movie, I-Robot, had some pretty cool ball-drive vehicles. I finally saw it a couple of months ago. Travis was pestering for almost a year about this, and I finally had the chance to see it. Thanks to Travis for the heads up.
Andy B.
  #15   Spotlight this post!
Unread 30-10-2005, 23:40
Sepsis900's Avatar
AKA: Alex Bachmanov
After a bit of discussion and brainstorming, we came up with a few ideas on improving the ball drive we've seen. One of the ideas is to support the weight of the robot the forward-backward drive wheels. That is, we'll put the drive wheel right above the ball and transfer the weight of the bot through the drive shaft and wheel onto the ball. This should alleviate some of the wheel-to-ball traction loss. However, this creates another problem: the other drive wheel will spin the ball in such a way that it will move perpendicular to the direction of top wheel's thrust. To use a metaphor, this is like holding a car still, and moving the ground under it to the left. We're going to need an omni wheel to handle this, but we will need one with thin free-spinning wheels to "bite into" the rubber of the ball. So here's my question: Does anybody know of any place that sells something like this? We might make an omni wheel like this ourselves, if nothing else is available, but we'd rather buy than make, because there's a lot of room to make mistakes on scales as small as this. If you guys can help us out at all, we'd really appreciate it.
On a tangent, the entire concept of a "ball drive" has turned into the subject of many immature jokes. I was wondering if the Teknokats had to deal with people making cracks about the robot's "balls", or how the team had the "balls" to make such a "ballsy" robot, or how you have to take a look at the robot's "balls" if you want to understand it.
[WHUMP]
[CLUNK]
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
