Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 01-11-2005, 16:32
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
drilling into sprockets
we have these HEAVY sprockets we would like to drill holes into to lose weight. they are the black ones. im assuming hardened steel. we've tried carbide bits, cobalt bits, and regular bits and each one burns up with one hole or less. we have been applying oil generously but they still die on us. what are we doing wrong? we drilled lots of holes in the same sprocket with one bit with no problems before. and we barely had to use oil then.. we arent sure which bit we used back then but we know it was a 1/2 in bit. same as what we are using now. why can we not drill a 1/2 in hole into our sprockets without killing them? or we know we can take off the hubs. can a bandsaw cut them off? (we are not allowed to use a lathe... this is for OCCRA. which lathes are not allowed.)
well, any other way we can drop weight from these sprockets? (we are not allowed to use smaller sprockets/chains.)
[OCCRA]: Rule Clarification- Motors and Sprockets Alex Golec OCCRA Q&A 1 20-09-2005 19:37
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
8" wheelchair hubs and 25 tooth sprockets Kirk Stankiewcz Kit & Additional Hardware 9 14-12-2004 19:54
[OCCRA]: the motor sprockets greencactus3 OCCRA Q&A 1 22-09-2004 20:11
sprockets from mscdirect Max Lobovsky Kit & Additional Hardware 5 29-01-2004 23:59
