pic: Lego Robot for a F.I.R.S.T.-ish Game
Re: pic: Lego Robot for a F.I.R.S.T.-ish Game
i highly reccomend shortening your wheelbase or widening the track or using less grippy tires. you would have trouble turning iwth that setup. and i highly reccomend you learning how to use "Reinforcements" to make a stronger. more reliable robot with less weight. beam on beam on plate only works for so long.
and as for max amps from a rcx, do keep in mind its possible to use battery boxes and use an rcx to change the switches. doesnt drain the rcx batteries as fast either. have fun! |
. The weight is no issue. Right now I am actually planning to add weight blocks for a counter balance, but this is one of those test it when it is done things. |
Also something you want to consider is if you want to run all of the motors independantly is that each rcx has 4 outputs, my idea of how ur planning on doing it would either require that second rcx, or run your brush off one of your other motor outputs, but that limits it a little bit, you probably knew all of this tho, just thought I'd make sure you did.
If you want two motors to run at the same time all the time, try putting them both on the same output port. If that doesn't work, then link two RCX units somehow.
Thats amazing. My team is really behind right now. But, they have a GREAT mentor (Mat Temme) and I believe they can get it done in time. (I can't help with programming, I help make the mechanical parts) Will this bot be at a FLL comp?
[off topic] You own the game pit! that is awesome! [/off topic]
Looks cool man, good luck in competition. |
| 2002 game prediction contest!!! | Ken Leung | Rumor Mill | 41 | 31-12-2007 18:18 |
| pic: Robot? What Robot? | CD47-Bot | Robot Showcase | 13 | 10-04-2004 07:08 |
| team 25 robot pic | nuggetsyl | Robot Showcase | 12 | 21-02-2004 00:57 |
| Online Game and Robot Quiz | Metalhugginman | General Forum | 11 | 13-02-2004 14:21 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
