Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Unread 02-11-2005, 09:55
laney836 laney836 is offline
FRC #0836 (robobees)
laney836 is an unknown quantity at this point
Send a message via AIM to laney836
Sprockets
Does anyone know where to find large approx 2 foot in diameter sprockets?
Unread 02-11-2005, 10:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Sprockets
What ANSI # or chain pitch are you looking for. #35 is pretty common for FRC. (if FRC is what this is for). However, I don't think you're going to find something that large, at least not in that pitch. A company called Azusa Engineering makes a nice 114 tooth aluminum one (for gokarts) part number 2699-114 which measures 13.829" in outside diameter, has six 1/4 inch holes on a 5.25" circle, and 4.563 ID. If you are going for a large reduction, I believe the smallest sprocket you are going to find is a 9 tooth. This combination would give you a 12.67:1 reduction.
Unread 02-11-2005, 19:05
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: Sprockets
or are you thinking for like a turntableish? you odnt need a full sprocket for that. just have a couple teeth every so often around a round disk. find a way so the chain always rides the teeth (when they come around) and you can have a MUCHO lighter "sprocket"..
Unread 02-11-2005, 19:46
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
Re: Sprockets
Like this?
Not exactly 2ft diameter but its a #35 aluminum 99 tooth sprocket
Name:	Robot 05 (160)s.JPG
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
drilling into sprockets greencactus3 Technical Discussion 18 06-11-2005 15:06
[OCCRA]: Rule Clarification- Motors and Sprockets Alex Golec OCCRA Q&A 1 20-09-2005 19:37
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
[OCCRA]: the motor sprockets greencactus3 OCCRA Q&A 1 22-09-2004 20:11
sprockets from mscdirect Max Lobovsky Kit & Additional Hardware 5 29-01-2004 23:59
