Go to Post To me, as a student, it doesn't really matter how old the RoboCoach is. My only concern is that they don't get ape-crazy when the game starts. - AZNkommander [more]
Unread 03-11-2005, 01:27
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Additional field coils around motors
I know everyone always wants more power form their motors, and that we aren't supposed to open them up to mess with them, but if you were to wind additional coils around the motor, could you increase the field strength legally?
I was thinking something along the lines of a series wound or shunt wound coil at first, but those are for AC electric motors, and only go in one direction.
However, if you were to have the field coil on its own speed controller, you could vary the strength of the field for when you need it.
This would be considered a custom circuit, so reading R52 from 2005
Inputs to custom circuits may be connected to the following sources:
Branch Circuit breaker outputs
Speed Controller or Relay module outputs
PWM or Relay outputs on the Robot Controller
Switches, Potentiometers, the outputs from Accelerometers, Sensors, and other additional electronics allowed
So it would be legal to have the inputs of this circuit (the power inputs) connected to a Victor, at least as how I see it.
So it would be setup so that once you hit full power on the motors, you start powering up the field coils around the motor to increase the strength of the motors.
Granted it wouldn't be that easy to wind the coil so that it's field matched that of the CIM, and there already is so much power available, and current draw is allready pretty high. Would it be legal, and beneficial to make a setup like this? Maybe as a big red button for when your in a shoving match or something.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 03-11-2005, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Additional field coils around motors
What about just putting a steel band around it like the fisher price motor has?
Unread 03-11-2005, 21:46
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
So, if we fabricated a motor mount out of a steel band that wrapped around the CIM, the motor might have a slightly higher power output?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 03-11-2005, 23:04
Team Role: Teacher
In a post I'm too lazy to search for right now Joe Johnson said something to the effect of "if you can pick up a large paperclip with a motor, chances are the motor could benefit from an external flux yoke" (I think that's what it is called) "Torque can be increased up to 20% in some cases"
And you'll notice the FP motor has one of these doo-dads and apparantly it serves a very important purpose.
So, I haven't tried it, and I haven't yet learned about magnetic flux and whatnot (I think about 3 weeks away from learning about that in Physics) but it sounds logical and I'd definitely be willing to try it. Does anyone know if you can pick up a paperclip with a CIM?
Unread 04-11-2005, 00:08
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
the effect of increasing the strength of the field is twofold:
1. you will have more torque for a given voltage
2. your top speed will be lower
the reason for #2 is the stronger field will generate a larger counter-EMF, the back voltage that determines the motor top speed.
Unread 04-11-2005, 07:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Dave is the closest thus far, the motors already have a magnetic structure designed in. Trying to add to that will likely not result in an increase in performance. However, under another rule, solenoids are not allowed. See also the robot allowed parts flowchart.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-11-2005, 08:14
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
True. But it's not the result, but more the intent that bothers me.
Unread 04-11-2005, 09:20
Unsung FIRST Hero
Rookie Year: 1996
Al
WB9UVJ
www.wildstang.org
Unread 04-11-2005, 09:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
I believe that Jack is concerned about the collective state of mind of a team that encourages them to bend the rule in this manner.
I'm not sure that it's unhealthy to try to push the limits, to exploit loopholes and to generally make life a mess for the inspectors and rule-makers. It's occasionally a little frustrating for those officials, but ultimately, it's mostly harmless. If the inspector or rule-maker says "no", it's final, no matter how much effort you put into it; by bending the rules, you take the risk you will find yourself in that situation. (Now, I should point out that decisions to live on the cutting edge should be undertaken with the consent of the team as a whole. If it's a small group within the team that risks the team's success on a dubiously legal enterprise, which is eventually rejected at a competition, all hell might rightly break loose in that team's pit; just leave the inspectors out of it.)
Unread 04-11-2005, 09:47
Unsung FIRST Hero
Rookie Year: 1996
I think that is important to note that winning teams have won without bending the rules. GP allows you to go ask, investigate and take pictures. Learn from others when you have the chance.
Al
WB9UVJ
www.wildstang.org
Unread 04-11-2005, 12:15
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
[quote=Tristan Lall]I'm not sure that it's unhealthy to try to push the limits, to exploit loopholes and to generally make life a mess for the inspectors and rule-makers.QUOTE]
Agreed. Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. Railing against them is unproductive, which is to say lets have fun with the ideas.
Unread 04-11-2005, 13:21
accepting the limits of nature? Im not too sure about this
many times it wasnt nature, it was our understanding that was flawed.
Several years ago 2.8k modems were the best you could get, because Nyquist said that is the fastest that data can be transmitted on a phoneline with a 3,000 Hz bandwidth
but now we have 56k modems, on those phonelines with the same 3kHz bandwidth
nature folded on that one and gave in. Sometimes it pays to keep railing :^)
also, sometimes when you sit and ponder ways to cheat, you come up with a good idea that is not cheating - unrestricted brainstorming!
Unread 03-11-2005, 04:39
Retired
Take another look at <R31> - What part of "So that every robot’s maximum power level is the same," don't you understand?
Unread 03-11-2005, 09:01
Team Alumni
Yes it says that, but looking at it in context it says after that "the motors in the kit may not be modified except as follows" and the purpose of this would be to do that without modifying the motors.
Sanddrag- Yeah it would be pretty easy to do that, but whats the fun in doing something that you know is going to work allready I'm not going to be actually trying this on anything, just thinking about it.
  #15   Spotlight this post!
Unread 03-11-2005, 09:14
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Jon,
I believe that any such an attempt would be violating the spirit and intent of the rules.
Years ago, Woodie and Dean asked us not to be lawyers. I would echo that sentiment.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Looking for Official FRC Competition Field plans sanddrag General Forum 6 17-10-2005 07:58
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
How does one go about ordering more motors... Team852 General Forum 3 27-01-2003 14:37
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
