Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 07-11-2005, 21:42
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Question Bend Radii
I'm currently working on an endcap much like the ones included with the kitbot, but adapted to hold 20-20 extruded. My question pertains to bend radius annotation. The kitbot's bends are labeled as .62 r, but what does this mean? I've measured the radius of the actual bends to be about 1/16", so is this annotation a coefficient you put in front of the actual material thickness (1/8 by .62 is around a 1/16" bend)? I'm assuming so, but we know what assume does...
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 07-11-2005, 22:57
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Bend Radii
1/16" = 0.062(5). It's probably a typo where someone dropped the 0
Unread 07-11-2005, 23:30
FRC #0306 (CRT)
Re: Bend Radii
Wow, I feel dumb now. Thanks, that would make alot of sense.
-Sir Francis Bacon
-Albert Einstein
Unread 08-11-2005, 00:30
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Re: Bend Radii
This is correct.
The bend radii is determined by the die used in the sheet-metal break.
Our typical sizes are .032", .046", .062", etc...
Andrew,
Where is this misnotated?
How sloppy of me.
JV
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 08-11-2005, 09:57
FRC #0306 (CRT)
Re: Bend Radii
It's in the chassis part drawings pdf. Chassis Parts
No big problem, I just didn't quite understand what was meant, and thought I'd try to learn how such bends were labeled.
By the way John, I was extremly impressed with the performance of the kit frame! I originally thought, like many others, that it would not hold up, but it has been the most reliable frame we have had to date! I'm looking to couple the best of both worlds in my modification: Multi-axis strength with the item extruded and it's fastener ease, with the incredible strength of the endcaps and the frame shape they foster.
-Sir Francis Bacon
-Albert Einstein
Unread 08-11-2005, 13:30
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: Bend Radii
John,
The error is in the notes section on each drawing.
At least you were consistant - all of them indicate the bend radii is 0.62 (Where's a good checker when ya need one?) Sorry, couldn't resist. I know it's tough being both designer and checker.
Mike
Unread 09-11-2005, 10:21
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
Rookie Year: 2000
Re: Bend Radii
Originally Posted by meaubry
John,
Mike
Mike,
Yeah, I just noticed that.
Obviously our manufacturing guys weren't confused by the error.
"They knew what we meant." (Isn't it dangerous, when metal guys "know better" than the engineers?)
JV
