| Thread Tools |
Rating:
Display Modes |
Lift on cart
Teams using pneumatic lifts, how is your lift system designed? Our team is adding a lift to our cart and I could use some ideas.
Re: Lift on cart
IM me and i will give you some good tips. I work for a medical company (Stryker) as an design engineer for the test lab. We make hospital beds and stretchers and EMS cots. They are hydraulic, but I use pnumatic components every day. Hit me up.
Re: Lift on cart
i was actually designing one that had a scissor lift and you could raise and lower it with ether a drill motor or this old sowing machine motor i have haven't finished the design yet but once i do ill get you the inventor files
Re: Lift on cart
I need to advise you that pnuematics are a bad idea for robot carts. They carry a fast response and little control for such a large and heavy object in such a small and confined space as a pit at competition. I know of teams that were asked to disable a pnuematic cart during a competition due to the danger to team members and other pits.
Re: Lift on cart
If you put in some good flow rate control, I think it could make quite a fine system.
Re: Lift on cart
Team #388 uses a lift cart from HarborFreight that has been modified with a new suspensiopn and wheels, this provides us with 660lb lift capacity up to around 40" or so.. waay more than we need. The advantage of this is the hydrolics are all preengineered and reliable, we can carry pretty much anything we want on our cart includeing our crate 2 years ago, and its very controllable with an handwheel that opens the lowering valve and it will up to a maximum speed which is very safe. I dont have any pics of our cart at the moment but will post some if I can rember also check out the cart pics on this site, many good ideas. Also I think the HOT team (cant rember the number) uses an linear screw actuator system with a sissor lift however I think the weight limit is very low
Re: Lift on cart
If your team is going to the Championships, and you have to push a 200+ pound cart back and forth the quarter mile or so from the pits to the Georgia Dome for each match, you will really want a lighter cart after its over. Going with a minimalist approach to cart building is best. |
Re: Lift on cart
in my opinion your options are either,(1)build a heavy cart with a sissor lift, (2)get a cheap dolly, or (3)attempt to make something new that no one has come up with yet. currenty myself and some other team members are working on option three, and have explored many options. Instead of a lift maybe consider making a table/cart... we might show our designs latter, if not you could always check it out when its done at our regionals. Currently i know we are going to the UTC.
Re: Lift on cart
If you have a pre-existing cart that works well, several hardware stores carry folding table legs (much like on folding tables, etc.) that are easily attached and require little to no technological know-how.
#10
Re: Lift on cart
I agree with the KISS method - Keep it Simple.
Instead of raising the robot, can you lower your chairs to sit while working on it? Maybe make some wooden rectangles with casters as chairs? We have had one excess in the past - the robot stand on the cart is a lazy-susan from the hardware store. Let's you rotate the robot while working on it or loading/unloading. |
| Robot Cart Questions from a rookie team | Alex Minot | Technical Discussion | 36 | 06-03-2006 09:20 |
| Shopping cart wrangler bot? | Taylor_Ratliff | Chit-Chat | 4 | 10-10-2005 15:31 |
| SnugTop Lid Power Lift Kit?????? | Mejinez | Pneumatics | 1 | 07-10-2005 01:48 |
| Robot Pit Lift | Burg | Pneumatics | 19 | 14-03-2005 19:38 |
| Extension lift mechanics | Steve Compton | Technical Discussion | 8 | 25-01-2005 15:47 |
