Go to Post If people are getting offended at seeing other teams list their accomplishments, maybe they should spend less time whining and more time doing things to make their own team win. - artdutra04 [more]
Unread 25-11-2005, 16:14
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Encoder Output Problems
I have a Grayhill 63R128 encoder, an Atmel STK500 development board and a LeCroy 9354M oscilloscope. I have it hooked up like so:
Encoder Positive In -> 5vdc pin of Atmel Development Board
Encoder Ground -> Ground pin of dev. board
Probe 1 -> Encoder Output A
Probe 2 -> Encoder Output B
Probe 1 Gnd -> Board ground
Probe 2 Gnd -> Board ground
However, it's not returning a square wave back. Here's the o-scope screen dump http://img.photobucket.com/albums/v7...screendump.jpg
Thanks,
Mike
http://www.mikesorrenti.com/
Non Contact Magnetic Encoder with PWM Output Tom Bottiglieri Programming 3 09-10-2005 01:19
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
